Old 12-21-2016, 11:59 PM   #1
Jack
junkman
Jack's Avatar
Default 66 122 - The car I shouldnt keep but like too much
I dragged home another car.
My first 122. 1966 b18 m40 car. Respray paint but seems to be holding on well and one color for the most part. Car has almost no rust. It sat for 5-8 years depending what story I want to go with from the PO
poured some gas into the carb and it started up on the second try.
so far
I got "new" wheels and tires from Luke
locking gas cap, filler neck seal, wiper blades, radiator cap and rear reflector from HiPerformance Auto
changed oil (delo 15-40) and filter
replaced clutch slave from IPD
adjusted valves and added a cork gasket
I drained the old gas - no rust inside the tank - thankfully
Drove it today for about 3 miles
high on the priority is to replace the exhaust - its all original and I only like the CO2 smell so much inside the cab
one of the steering arm links is bent
someone added a period correct hazard switch - the red lights up when hazards are on
I also picked this up 65 122 from the local yard
Old 12-22-2016, 12:07 AM   #2
122power
dude
122power's Avatar
Get the sport exhaust it sounds good. Or just a 2" system.
Old 12-22-2016, 12:11 AM   #3
Jack
junkman
Jack's Avatar
will buy a header and probably build something from all the exhausts I have left over.. Might put on the Anza muffler from the 245 since its too small for that car
Old 12-22-2016, 12:42 AM   #4
Nice score(s). Do you plan to make them both run or is one a parts car?
That hazard switch might just be an original Volvo accessory.
Old 12-22-2016, 01:01 AM   #5
Jack
junkman
Jack's Avatar
the other is just a parts car, junked title
nice the hazard is the one on the left
Old 12-22-2016, 12:21 PM   #6
Old 12-22-2016, 01:19 PM   #7
wtarkington
Nice car. Parts car doesn't look bad either.
wtarkington is offline   Reply With Quote
Old 12-22-2016, 01:45 PM   #8
Jack
junkman
Jack's Avatar
parts car has a nicer interior then this car. still shot 50+ year old but the color is the same
as the stars get chipped this will forever be on the front page ....
Old 12-22-2016, 04:22 PM   #9
Jack
junkman
Jack's Avatar
new cat showed up at my house today... I woke up and she was just chilling next to me...
I decided to clean out the interior a bit today and see the rust damage on the floor boards. It's a lot better then I expected, mostly surface rust with few holes. Should be fun to patch these. (pictures make it look worse then it actually is)
Soaking the parts in Krud-Kutter
Can someone tell me if the plastic parts were polished when new or were they always matt?
before cleaning
took out the crusty floor matt and started to peal off the sound deadening
driver rear - has the worst rust. All the water would trapped under the floor matt and eventually found its way out. Thanks OBAMA
passenger rear
nothing like a wet dog smell, though I bet I just replaced that with wet horse smell. I will be removing the seatbelts and pressure washing them. One of the belts has a '68 date stamped on it, I bet a dog chewed up the original.
Quick pressure washing to remove all the grime before I get in there to remove the rest of the sound deadening
after pressure washing the dog out
Im on the fence about the sound deadening material. The choice is between Lowe's Chepo roofing Peal n Seal
or Dynamat. I have used both before, of course the dynamat is the way to go but expensive.... But Peal-n-Seal would be better then factory or nothing even...
what do you think ?
Old 12-22-2016, 06:42 PM   #10
122power
dude
122power's Avatar
Id just throw the 240 sound deadener in there. They always rust in that back floor pan.
Those rubber floor mats never let the car breath so they rust. Cat.
Use some #0000s steel wool on those chromepieces. Spraying some wd40 on there helps as well or after your done and wiping it off keep it nice for awhile.
Old 12-22-2016, 08:42 PM   #11
Steel wool or #1000 gold scotch brite will put a fine scratch on it, I'd use metal polish or if it's chromed steel and there's rust poking through I'd rub it ever so gently with a stainless steel pot scrubber.
Old 12-22-2016, 08:51 PM   #12
Coupid
Coupid's Avatar
awesome looking project, congrats!
1972 142S Project Thread: http://www.turbobricks.com/forums/sh...d.php?t=311926
1991 780 Sold
1979 244DL Sold
1986 740+T Sold
1983 242T Sold
Old 12-22-2016, 10:12 PM   #13
timpanama
timpanama's Avatar
Company called FatMat works great!
timpanama is offline   Reply With Quote
Old 12-22-2016, 11:17 PM   #14
Jack
junkman
Jack's Avatar
IDK 0000 works good for me
thank you, you should buy it
I already have a bunch of Dynamat and loved it on my 245 but like said both are expensive and PNS is cheap but not as effective - anything is better then no deadening
decided to polish my knobs and repaint the lettering on switch plates
before
1/2 done
with the lettering you have to cake on the paint, wait for it to dry and rub off the excess
could be better but I'm done with these
Old 12-23-2016, 01:55 AM   #15
122power
dude
122power's Avatar
looks good
Old 12-24-2016, 09:32 PM   #16
Jack
junkman
Jack's Avatar
just small updates but very time consuming
polished one tail light and surround. Left the other one alone since it's broken. I wont install this one until I get new tail light gaskets from Eric
someone tell me if that much gap on top and bottom grille is normal or what the story might be
Decided to take the bumper off to tighten, straighten and clean it up. The driver side override was loose and would rattle all the time. It took a lot longer then it should have, bolts inside the overrides were unreachable so I cut them off and welded a bolt inside the bracket. Took me forever to get it back on since I had to loosen up the bumper brackets and then try to realign them. I also installed a late model license bracket to center the plate.
before
after
I forgot to take a picture of the bolt welded inside this bracket. I also had to hammer it flat before that.
Old 12-24-2016, 11:29 PM   #17
The gap at the top and bottom of the grille is a result of the center bar being pushed in. It's also why there's a gap between the hood and front panel.
This is how it should look.
Thanks for fixing the license plate. It's a pet peeve of mine. They're either too high or too low without the bracket and just don't look right.
Old 12-24-2016, 11:36 PM   #18
Dangerkitty
Bored Member
Dangerkitty's Avatar
What did you use to polish the knob?
That came out looking good.
just a bunch of bicycles and a 71 145 GT project
+ a 1982 Dodge Xplorer 221
Dangerkitty is offline   Reply With Quote
Old 12-24-2016, 11:37 PM   #19
Jack
junkman
Jack's Avatar
^ but nothing on the front panel is bent or damaged? It appears to be bent in pictures maybe but I checked and it's just a respray
I mounted the plate low also but to me it was also just a dumb. I did it for you Ian, you welcome
Thank you. Just metal polishing compound on a buffing wheel, blue stuff called Blue Magic Metal Polishing Cream found just about everywhere. If I would have spent more time it would look brand new.... maybe when the rest of the interrior is done I'll go back
Old 12-29-2016, 02:26 AM   #20
Jack
junkman
Jack's Avatar
turns out my 122 has been out at night banging the local "ladies" and bringing them home
craigslist add
Selling my 63 volvo wagon and all my spare parts. 2 extra parts cars, engines, transmissions, overdrive, doors, fenders, hoods, trunklids, boxes of emblems, switches. Ect. More than enough here to make a solid car with. Just don't have time to do it myself. Too many projects
I just came back with all the "loose parts." Im going back for the cars next weekend
62 wagon - clean title, pink in hand but the previous owner never got it registered from the pre previous owner - signed 2012
the other two are coupes with no title but havent been registered in over 10 years. I need to write up a "statement of facts" for the dmv
pictures to come when I drag them home.... BTW all but wagon will be for sale
will probably keep the wagon - needs passenger side floor- its been cut out
no engine - and trans tunnel has been cut out - very little rust in the floor
driver door is fubar - but came with 4 extra ones
this one has an efi b20 in it - no rust even in floors
Old 12-29-2016, 10:43 AM   #21
kampman
dunning-krugersquirt
Any chance there's a spare set of bumpers hiding somewhere in that pile?
1966 220 wagon: dormant resto project
1999 S70 manual: #base, 192K
2000 V70R: 135K, deer victim/just a flesh wound
2006 V50 T5 AWD 6MT: 135K
Feedback Thread
Old 12-29-2016, 10:45 AM   #22
gsellstr
Vintage anti-ricer
gsellstr's Avatar
You are welcome Jack.
Glad you were able to snag the piles!
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 12-29-2016, 01:57 PM   #23
Jack
junkman
Jack's Avatar
Yes
Me too.
Thanks for "just the tip" Gary
Old 12-29-2016, 03:35 PM   #24
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Hey, I know when enough is enough, unlike you.
Old 12-29-2016, 05:00 PM   #25
wtarkington
Wow you got the motherload!
