740tankDriver
Post-Hypnotic Sigma
- Aug 18, 2006
- Under your nose.
well that connector i was not sure of it's function turns out to be the connector to fog lights. so, if i plug in the relay for fog lights at the fuse/relay hub then all that's left is hooking up the switch to the foglight system. how is that done? what goes where>?
i'm really not interested in a hack job, when i said all required for plug and play i meant it. as many of the original factory wiring as possible. now though, i have to think...how will these fog lights work? what's the order? meaning, can they be switched on at any point of vehicle operation? (during parking lights, main head lights, high-beam operation)
and further more, is a separate relay really necessary for the auxiliary high-beam lamp? or would it illuminate when the main high-beams are on?
