Acid8000
- May 3, 2005
- Victoria, BC - Canada
I'm having a hallejuh of a time getting the caliper mounting bolts out so I can get the rotor off and repack my wheel bearings. Wondering if I can just open the calipers, they are the design where it's just one side piston. Speaking of; which are those anyway il need to know for future brake pad change.
1986 740ti
So Yeah, once you open the caliper you can like swing it up. Can you then at that point remove the rotor and get at the bearings. Or do I have to remove the caliper mounting bolts and swing the whole caliper assembly away..
1986 740ti
