Old 10-02-2016, 11:52 AM   #1
Wavesproject
Default Wave's 242R-Project
Hi everybody,
I have couple of Volvos and one ongoing Project. In this Project i will use a little bit different engine option. I will not use turbo because I prefer old American muscle cars.
This is my first bigger Project and i hope you find it interesting.
Fitting the wheels.
Front spring parts
Front bottom arm welded
Bracing kit for rear bottom arm
Rear bottom arm welded and sanded.
Wavesproject is offline   Reply With Quote
Old 10-02-2016, 12:23 PM   #2
nel621
Double wide axles front and rear, not bad.
Old 10-02-2016, 06:06 PM   #3
adomz
Volvo 486 owner :D
adomz's Avatar
Hey! Welcome!
Should be interesting! ;)
ADam
Errr.... 242... No engine no cringdingding...
=->Adam's youtube channel<-=
adomz is offline   Reply With Quote
Old 10-03-2016, 05:53 PM   #4
Wavesproject
Adjustable upside.
I saw this Bamse's a volvo and I decided to do the same.
Old 10-03-2016, 06:09 PM   #5
Wavesproject
Corsa's electric power steering if I cant turn the steering wheel because wide tires
Fuel system, in one go.
Old 10-04-2016, 04:36 PM   #6
Wavesproject
First blew all the parts, then powderpainted them, paint and varnish. I hope that now they can withstand heavy use.
I need to modify the oil sump.
I tried the plasma cutter.
Now parts are ready for welding.
Old 10-04-2016, 04:56 PM   #7
Wavesproject
Lightweight flywheel
Plate of sintered, I hope that it is tolerable to use.
Old 10-06-2016, 04:32 PM   #8
Wavesproject
Oil breather made in one go
The engine is ready, missing only the rest. It is X25XE/X30XE series, whit some extra little thing, you now....
Old 10-07-2016, 05:08 PM   #9
Wavesproject
The pistons have been taken BMW M3 to.
Engine cam shafts honed on street fit.
The own production of adjustable cam gears.
Front brakes taken from the Mitsubishi Lancer Evo. Sandblasted first.
Then powderpainted them, paint and varnish. Rear brakes has the original front brakes.
Old 10-08-2016, 01:13 PM   #10
Wavesproject
Block is prepared for painting.
Block is primed.
Block is completed.
Pistons and rods together in perfect harmony. The top of the piston is coated with ceramic after machined, the compression ratio is 12.5 and the fuel is ethanol.
Yes, there it goes.
Old 10-10-2016, 02:27 PM   #11
Wavesproject
The original engine inlet duct.
The original engine exhaust passage.
Modified engine inlet duct.
Modified engine exhaust passage.
Changes succeeded well, cylinder heads flow 345 hp in 10 drawing. Exhaust 76 %.
The engine combustion champer is ready.
Old 10-10-2016, 02:40 PM   #12
Wavesproject
Oils for engine, gearbox and rear, Redline, of course.
Anti-roll bar mounts had to be renewed. Bushing from Ford Sierra Cosworth.
Old 10-10-2016, 03:02 PM   #13
GTJordan
Been here for too long
GTJordan's Avatar
I'm not sure what happened, but all the pictures are broken, except the first post.
Edit-returned a bit later and it's all working!
Old 10-10-2016, 04:27 PM   #14
Arn02
Arn02's Avatar
Opel engine... highly original! Nice work.
I see all the pics btw.
Ambitious but rubbish.
The 245 GT
The Euromurican
Old 10-12-2016, 02:38 PM   #15
Wavesproject
Upperpart Strengthened
The brake servo sanded clean.
The brake servo covered whit structure paint.
Old 10-16-2016, 01:45 PM   #16
Wavesproject
I will make a big aluminum tank on the top of the shaft- this will maximise the capacity in the booth. Capacity 80 liters.
The interior is so neat that i want to keep it as original as possible, but the seat should be sportier.
Here it is.
Hand brake parts
Old 10-17-2016, 01:23 AM   #17
Arn02
Arn02's Avatar
I already mentioned the originality a few posts above, but I'm just commenting out of respect again. You have some very creative ideas. Love the seats.
Old 10-18-2016, 04:13 AM   #18
Estoque
Estoque's Avatar
Are these the V6's out of the Opel Omega etc?
looks good!
Compensate bad aerodynamics with BST - Volvo 245 B230FT Turbo
Estoque is offline   Reply With Quote
Old 10-19-2016, 04:15 AM   #19
Wavesproject
Thank you for the positive feedback
Jep, you can get this engine from Opel Vectra ja and Opel Omega. And Omega MV6 model.
My friend has this engine guite original and the engine is really rancid and received oxygen really drastically without any problem for over ten years. And the best thing is the sounds which resemble boosted motorbike.
I started to thing about how good this engine can get if I tuned it properly. Well, I will se it next summer, hope.
I think too that seats managed very fine, factory-sighted and supported me very well
Old 10-19-2016, 07:44 AM   #20
Thor
Thor's Avatar
wow this is amazing. I cant wait to see it all put together.
1991 240 M-47 daily driver
Build thread: 91 240
Feed back: Here
Thor is offline   Reply With Quote
Old 11-03-2016, 03:25 PM   #21
Wavesproject
I put two coolers into the oil lines.
And oil battery to save the engine full disaster, I hpe
Old 11-03-2016, 03:45 PM   #22
Dammit
+8cm
Seat idea is genius.
Dammit is offline   Reply With Quote
Old 11-06-2016, 09:26 AM   #23
babbit bearings
Hello,
Where did you buy these?
Thanks
Craig
babbit bearings is offline   Reply With Quote
Old 11-16-2016, 02:24 PM   #24
Wavesproject
Hi,
sorry for late reply. I buy the parts from this address www.rallyracefin.fi.
Old 11-16-2016, 02:27 PM   #25
Wavesproject
