impolvo
Is always busy
- Feb 23, 2006
- Chapel Hill NC
Resurrected after may years the 262c with d24t m46 did great
Pulled fine for what it is was getting 8-11 lbs boost
Changed all fluids belts
Fuel filter twice once after 59 miles
Was very old fuel
It’s a little hard to start (under powered battery
Like 550 cca 70ah
But today it finds emwant to jump to life like normal
Needed a jump start and many turns
Took it around the neighborhood but occasionally would not rev over 1k
Even parked in neutral but randomly would decide to work as normal
Any idea?
I know I plan on an in line electric pump to help the injection pump
But no matter how much throttle it wouldn’t muster over a 1000 rpm
Then random moly it’d go away and be boost happy
It’s I thinkable engine from an 85-86 760
Any things that might be restricting it
I swapped glow control module so it’s firing the plugs now
Though I haven’t checked if they are good
No fuel leaks
Just oil from a Ames oil relocation kit
Was very old fuel
Like 550 cca 70ah
Any idea?
No fuel leaks
