Well.... Finally back at it. Crazy projects at work and snow brought things to a halt for a bit there. I have been trying to sort out some things. Longer exhaust housing studs to fit the ATG ultimate gate with but Fastenal has a solution for me on that.
Here's one question however.... Did Volvo use more then one stud size on turbo manifolds? Are those for use with Mitsu's smaller diameter then Garrets? I have two 90+ manifolds with differing stud sizes. One fits T3's perfectly. The other, the diameter is smaller so the holes in the housing are essentially too big.
Come to think of it, I may have an extra TD05 I can use to check.
Otherwise....
Since I cut and rolled a portion of the fender well, it was time to re-seal it. Got that masked off and used some gnarly a55 3M stuff. Pure stank but it looks like it's going to do the job well.
Adjusting the ride height. After getting the rear suspension zipped up, I put the car back on the ground and it was still sitting too low in the rear. I'm actually after a little rake as opposed to the car looking like it's dragging it's ass.
When I get back into, the sealer should be dry. I'll sway sides and repeat.
The I'll finally finish rebuilding the front passenger side caliper. Hopefully Fastenal will have my order by then.
Last question: Anyone have any experience with the Chinese billet fuel rails for B230's?
On ebay.
