Old 05-10-2008, 04:15 PM   #1
sdturbo
sdturbo's Avatar
Default Electric power steering.
So my power steering pump was cracked when I got my 242. Decided to just ditch it and put an mr2 electric pump in.
http://www.youtube.com/watch?v=iItsdzTMp9I
Josh
92 245 (TDI diesel powered.)
84 242 (16vT beater/track slut)397whp/11.6@118mph Sold
97 Land Rover Discovery (Mercedes om606 swap)
65 Mini Cooper (B18 powered)
www.yoshifab.com Volvo performance parts.
(760)468-7002
sdturbo is offline   Reply With Quote
Old 05-10-2008, 04:21 PM   #2
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
I've been thinking about doing this as well. How was the install? Pics?
Old 05-10-2008, 04:32 PM   #3
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
sweet deal... my experiences with the volvo electric pump setup have been very good... that really is the only type i have driven though.
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 05-10-2008, 04:46 PM   #4
sdturbo
sdturbo's Avatar
It was quite easy, I just made a bracket to mount the pump to the finder well. I tried to take some pics but they dont really show anything. Its just an electric pump bolted to the car and normal lines like what you would have in a belt driven pump. Toyota uses some kinda ecu and sensor on the wheel to turn it on. This is not as sophisticated as i turn it on with an alegator clip at the moment. It will be on a toggle switch as soon as I have time to run to Radioshack. The whole swap is sitting around $20 at the moment.
The pump is out of a 2g toyota mr2. All you need is the pump and the relay. I took a piece of the high pressure line, cut it off and welded it to the volvo line. Not the most elegant way of doing it but hey it works.
Old 05-10-2008, 04:55 PM   #5
Karl Buchka
So the line pressures match up between the pump and rack? This is really my only concern.
It does seem like a really easy install. I'm definitely doing this now. Much easier than trying to adapt a 240 pump to the T5 accessory mount/belt.
Old 05-10-2008, 04:59 PM   #6
sdturbo
sdturbo's Avatar
haha no clue if the pressures match up. The power steering feels perfect, not over powering at all.
Old 05-10-2008, 05:12 PM   #7
Karl Buchka
It seems noisy in the video. Can you hear it over the engine? Any vibration into the cab or steering wheel?
Old 05-10-2008, 05:17 PM   #8
sdturbo
sdturbo's Avatar
You cannot feel vibration, i put it on rubber isolators. As far as noise, its not that bad inside the car. My car is gutted so eveything is loud. You cannot hear the pump over the motor with a stock exhaust though. No worse than a walbro 255 fuel pump.
Old 05-10-2008, 06:06 PM   #9
ShadowofBob
Revived...
ShadowofBob's Avatar
Pumps like that are really only noisy at idle while sitting. If the car is moving it's not really noticeable. This is a common modification for the Audi I5 20v cars.
1990 Audi Coupe quattro x3 - the eternal project car.
2000 Audi A4 Avant quattro 1.8T 5spd
ShadowofBob is offline   Reply With Quote
Old 05-10-2008, 06:46 PM   #10
sdturbo
sdturbo's Avatar
Yeah once the alt is spinning the pump really starts moving and it gets a lot quieter. If you want to get real fancy, get the sensor off then mr2 and the pump will only come on when you turn the wheel.
Old 05-10-2008, 07:40 PM   #11
Renny_D
Renny_D's Avatar
Kinda hard to see do you have pics? I'm interested in this for my volvo but also for my subaru. How much was the pump and do they come on anything other than the mr2s?
Thanks
Renny
90 740 T with a dented S90 exterior and interior, front mount fleabay 24x12x3 almost bumper cooler, 3"inch exhaust, IPD springs, Bilstien HD, KG2T cam, LSD, MSD 6A, CFIs @ 46psi, 960 amm, SSautochrome flipped header and Holset hy35 goodness and extra hp in a gymbag.. - MS coming - never track run this year so no idea about the combo's power - dyno day to come.
Renny_D is offline   Reply With Quote
Old 05-10-2008, 07:41 PM   #12
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
As far as pumps that put out too much pressure go, plumbing in an adjustable relief valve is a straightforward/cheap fix. If my rack doesn't like the 960 pump that is what I will do.
-Kenny
Old 05-10-2008, 08:45 PM   #13
sdturbo
sdturbo's Avatar
Thanks
Renny
Like I said, kinda hard to get a picture of anything. I fail at taking pics while i did it, it was like 2am and I didn't care about pictures.
Pump was $16.50 from the wrecking yard. Probally another $10 in hose, clamps, fluid and hardware. I had most of that stuff laying around though.
Old 05-10-2008, 09:15 PM   #14
Jordan
Jordan's Avatar
The hood is up annnnnd the engine isnt running. I doubt over the engine noise, you'd hear it. This is a dope idea.
My Buyer/Seller Feedback Thread
Jordan is offline   Reply With Quote
Old 05-10-2008, 09:17 PM   #15
Jordan
Jordan's Avatar
How does THAT work? What lets it know the steering linkage is spinnin?
Old 05-10-2008, 09:33 PM   #16
volvo944ti
hmm would solve fitment issues on teh pro turbo header!!!!
volvo944ti is offline   Reply With Quote
Old 05-10-2008, 10:40 PM   #17
sdturbo
sdturbo's Avatar
It gets quieter with the extra voltage the alt provides.
The mr2 sensor is basiclly a hall sensor that can tell when the wheel moves. It has its own ecu just for ps. I abandoned all that. Im trying to keep this car simple as possable. Im considering using it on my wagon though.
Old 05-11-2008, 02:10 AM   #18
blarf
blarf's Avatar
So what's the advantage with an electrical vs mechanical pump if the electric pump is going to be left on all the time?
Manuals moved here: http://gaz.inferiorhumanorgans.com/greenbook/
blarf is offline   Reply With Quote
Old 05-11-2008, 02:17 AM   #19
Lord Tentacle
Anime Lord
Lord Tentacle's Avatar
you can turn it on and off when you feel like it
Tentacle SUV 12 xc90; stuff including v8 and towbar etc... Powered by Beetroot
recently crushed Volvo's
Old 05-11-2008, 02:21 AM   #20
sdturbo
sdturbo's Avatar
When i nuke the motor/trans it will be easier to push it onto the trailer
Old 05-11-2008, 02:42 AM   #21
BB-Q
BB-Q's Avatar
Most cars with these fitted have a failsafe built in that prevents the pmp from working if the alternator output is below 14ish volts. Those pumps draw between 20 & 30amps and will flatten the battery very quickly.
Don't you guys get cars with electric steering columns over there?
Do you get these?
Most newish small cars here have electric columns- no hydraulics involved at all. I've been thinking it may be a future modification for the 142
Originally Posted by foggyjames View Post
The man is a pimp, and a fast one at that...
Originally Posted by frpe82 View Post
He's got that "crazy Mark" look in his eyes...........
1992 245 SE B200F, M47, Low and painfully slow.......
v8volvo240.com
BB-Q is offline   Reply With Quote
Old 05-11-2008, 03:56 AM   #22
tjts1
tjts1's Avatar
Very cool. How many amps does it draw?
I'm trying to adapt an AC clutch to a whiteblock PS pump so I can turn it off when Its not needed. Get rid of some of the parasitic drag.
Greed is good.
tits for president
tjts1 is offline   Reply With Quote
Old 05-11-2008, 04:26 AM   #23
sdturbo
sdturbo's Avatar
I dunno, i didn't check... the motor bogs less when i switch the ps on than the E fan however.
Old 09-27-2010, 03:02 PM   #24
badvlvo
Bad for Babies
badvlvo's Avatar
I like this idea. I'm not in love with the manual steering in my car.
That's not bad at all.
Died at age 35
Old 09-27-2010, 03:08 PM   #25
Crazychopstick
(/// _ - )
Crazychopstick's Avatar
Location: Receiving Transmission from David Bowie nipple antenna
Totally my next mod.
Crazychopstick is offline   Reply With Quote
