Old 01-29-2009, 09:33 PM   #1
DecalServiceBrett
Default Holset he351vgt
Did anyone ever figure out how to hack the electronic wastegate on the HE351VGT?
Didn't Poi buy one?
rofl
DecalServiceBrett is offline   Reply With Quote
Old 01-29-2009, 09:35 PM   #2
Lucky the Smiling Pirate
roadkill
Lucky the Smiling Pirate's Avatar
no, these are not the droids you're looking for
Lucky the Smiling Pirate is offline   Reply With Quote
Old 01-30-2009, 01:55 AM   #3
badvlvo
spambot
It couldn't be that hard to do. I don't have the electronic WG on my Holset so I can't play with one.
Buy this amp! http://forums.turbobricks.com/showthread.php?t=214308
Originally Posted by Chief U.S. District Court Judge Vaughn Walker
"race restrictions on marital partners were once common in most states but are now seen as archaic, shameful or even bizarre. Gender no longer forms an essential part of marriage; marriage under law is a union of equals."
Originally Posted by mullen1120 View Post
Problem solved, my dumbass left a paper towel in the turbo inlet
Old 01-30-2009, 02:38 AM   #4
dbh86
Notch?
dbh86's Avatar
Brett, did you try yet?
Kraken-pipe FTW!
dbh86 is online now   Reply With Quote
Old 01-30-2009, 08:23 AM   #5
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
hack? it should be just PWM.
-Matt
1989 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, 100lb delphis, 4.6 springs, bondo header, 12x24x3 ebayIC, w/c t5, clutchnet 4puck/PP, 4.10 G80, 370whp/360wtq
1990 745T- b230ft, 531 head, big valves, RSI rods, Cosworth turbo, w/c t5-z, full 3", clutchnet 4puck/PP, RC 550cc, MSnS-E, Forge 004, Fuso I/C, 4.10 G80
1987 Jeep Wagoneer XJ- 3" lift, nv-242, '95 4.0 head, intake and cam, AW30-43LE, dual lockers, 31's and some stereo stuff.
500dollar744ti is offline   Reply With Quote
Old 01-30-2009, 10:08 AM   #6
JohnMc
JohnMc's Avatar
I keep pondering using one of these. From what I've gathered:
1) It's PWM
2) When the vanes are closed, it might not be very appropriate for a gas engine (it can act like an engine brake on diesels?), might want to rig it to only close partway down.
3) Even wide open, when on a gas engine the boost will still keep climbing pretty high. So you'll likely need an external WG to go along with it.
Then there's the issue of what logic to use in governing the gate actuation. I think on the OEM fitment, the ECU is basing it on shaft speed, and that's one of the outputs (hall sensor?). Not sure if it's worth the effort of reading that though. I guess basing it on the boost pressure is probably about as good.
I saw where someone had just removed the electronic controller and replaced it with a normal WG actuator, on a little fabbed bracket. I guess that would work if you set its operating pressure somewhere below the WG operating pressure. For example, have the vanes set to open fully by 10 psi, then have the WG open at 15 psi.
I already have electronic PWM boost control on my 16T, I supposed you could probably get another PWM output going by using the dual table code and running the second injector output to the vane actuator.
Then I keep thinking perhaps I should just get a more conventional Holset (HE351CW looks nice, has an internal WG to make things easier). Or a nice ball bearing Garrett.
'63 PV Rat Rod
'93 245 Classic #1141
Old 01-30-2009, 01:05 PM   #7
DecalServiceBrett
I figured. I'm going to get one and feed it some PWM voltage.
Old 01-30-2009, 01:07 PM   #8
DecalServiceBrett
John,
Wouldn't it just be so dang cool if it had a shaft speed sensor, to have a turbo shaft speed gauge? That would just be so awesome.
Old 01-30-2009, 08:21 PM   #9
dieselboy
Tamed by a Kat
dieselboy's Avatar
http://himni-racing.com/index.php?ma...oducts_id=1205
-Jesse
'98 S70 T5 straight piped
'83 242 tic 16v turbo,,jvab internals, PZ cams, ms, coilovers, 1000cc injectors, 4'' intercooler, ttr cam gears, dale pulley, edis, ipd sways, 13'' brembos, tko600, rollin on 18" Atlantis, flathood, vdo gauges and more..
'66 122s no engine yet
'95 bronco7.3 turbo diesel
I think they want grandma photos. Not sure why, it's probably a 7-series thang.
dieselboy is offline   Reply With Quote
Old 01-30-2009, 09:16 PM   #10
JohnMc
JohnMc's Avatar
Some of the discussions I've seen around the 'net indicate that it already has some sort of sensor, but deciphering the signal and making a gauge would be beyond my electronic skills.
There also seem to be some sensors on the vane position, so the ECU isn't blindly going off a static PWM map, but dynamically positioning the vanes?
Old 01-30-2009, 09:29 PM   #11
84 Blue 240
84 Blue 240's Avatar
Brett, if you are serious (and this isn't another hair brained idea), I CAN get you all the info you need. My friend works as a development engineer for the big 3's diesel programs (outside contractor).
84 Blue 240 is online now   Reply With Quote
Old 01-30-2009, 09:35 PM   #12
Karl Buchka
lapping scottyd
Karl Buchka's Avatar
You're talking to the guy who, in short order, managed to ventilate the block on at least one bone stock B21FT because he never bothered to tune his MS.
No real power, just turbo shіt.
Whiteblock swap guide / Engine swap FAQ
Old 01-30-2009, 09:48 PM   #13
pooprah
Guest
your mom tunes ms better than brett
Old 01-30-2009, 09:50 PM   #14
Karl Buchka
lapping scottyd
I've actually shown her how to do it, so yeah, she probably does.
Old 01-31-2009, 12:01 AM   #15
boostin'xr4
boostin'xr4's Avatar
That's insane. I've beat on my 300k mile b21ft so hard at 30+ psi and it just wont die.
I just won't ping, though.
boostin'xr4 is offline   Reply With Quote
Old 01-31-2009, 12:03 AM   #16
DecalServiceBrett
I appreciate your sentiment. I blew up the B21ft because I had no O-ring at the oil return line and blew out all of my oil from crankcase pressure.
Thanks though. It was kyote's tune, and it worked fine.
Old 01-31-2009, 12:04 AM   #17
boostin'xr4
Ok for a second there I thought someone actually killed one of those things.
Old 01-31-2009, 12:14 AM   #18
DecalServiceBrett
It's impossible if you aren't giddy enough to check for oil blowing out.
Old 04-18-2009, 09:18 PM   #19
Shrike0064
I took my controller apart. Since it's no good to me as is. I'm going to use it on my Land Rover Discovery I in a STSturbo configuration.
The controller for the HE351VGT communicates to the main ECU in 2007/2008 by the new CAN protocol. Internally the motor is a brushless DC motor with (3) hall effects for rotor position feedback. Also called BLDC. It is configured in a 3 phase WYE configuration. Motor drive is by (6) FDD16AN0 / 8A0, N channel FETs. One terminal of each phase (coil) are connected together. But not directly to ground or +12v. The other end of each phase is connected to the junction of Drain and Source of two FETs in a push-pull configuration. If you just want to make it spin, a standard R/C brushless dc motor Pulse Width controller works but provides no position feedback. Could provide feedback by counting gear teeth. However, the motor phases are separate. Each phase is connected via the PC board and not internally. Therefore it can be controlled as a stepper motor. A count can be taken for any position between fully open and fully closed. 9 steps for 1 full motor rotation. At start up full rotation to minimum boost can be set. Then the number of steps counted for any position in between. I'm thinking of counting gear teeth for feedback either way. Currently working on a drive and interface method so I can hook it up to an aftermarket boost controller.
Shrike0064 is offline   Reply With Quote
Old 04-18-2009, 10:33 PM   #20
Captain Bondo
Jackstand Queen
Captain Bondo's Avatar
My car has an an oil light, it works awesome.
-Kenny
1983 240DL-T6
395whp @ 16psi, Mustang Dyno.
13.4@113
Stock junkyard motor. Header. Megasquirt. 960 cams.
Originally Posted by Group A View Post
It'll cost you way more than that by the time I'm done.
Ever been clipped in the rear corner at 100+mph?
Old 04-18-2009, 11:15 PM   #21
Mjolner
Mjolner's Avatar
Mjolner is offline   Reply With Quote
Old 04-18-2009, 11:27 PM   #22
DNAsEqUeNcE
Jesus Christ is Lord
DNAsEqUeNcE's Avatar
About that...
the 85 engine had just an oil pressure switch, and I had it hooked into the gauge.. I didn't know jack about b21ft's then.
Thanks for the holset information!
Isaiah 9:6
For unto us a child is born, unto us a son is given: and the government shall be upon his shoulder: and his name shall be called Wonderful, Counsellor, The mighty God, The EVERLASTING FATHER, The Prince of Peace.
Old 04-19-2009, 03:58 AM   #23
chenz
chenz's Avatar
Has anyone ever looked at a Jaycar boost controller?
http://180sx.locost7.info/boost_control3.php
http://www.skylinesaustralia.com/for...207.html&st=40
Ive used one, Ive changed cars since but I think im going to put it back on to make my m46 conversion last longer
chenz is offline   Reply With Quote
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
