Old 05-22-2012, 11:43 AM   #1
Mr. V
Mr. V's Avatar
Default 940 Manual Climate Control repair
1992 940 Turbo with manual climate control: it stopped working, as did the A/C.
Removed unit from dash, disassembled to expose circuit board, looked for evidence of failed solder joint (per repair link from brickboard): nothing visible.
Stymied, I took the unit to an electronic repair shop: the owner usually repairs stereos.
He tested it, found a bad solder joint and repaired it: took about 15-20 minutes.
I watched him do it: large, illuminated magnifying glass, myriad electronic test gear, specialized soldering and desoldering gear and techniques.
He said "no charge," but not wanting to impose I flipped him $20.
A new unit is reported to be about $400; a rebuilt one is over $200.
Old 05-22-2012, 12:32 PM   #2
TrickMick
Broad Member
TrickMick's Avatar
my eyes are soooo flaky I have to use a 10x loupe:
http://www.harborfreight.com/5-piece...set-98722.html
the "10x" one works really well....
In a closed society where everybody’s guilty, the only crime is getting caught. In a world of thieves, the only final sin is stupidity.
TrickMick is offline   Reply With Quote
Old 05-22-2012, 01:16 PM   #3
jerryc
jerryc's Avatar
He did you a favor. When I went to an electronics shop with the same issue on 3 of them he wanted $40 each.
I got the new relay, also as mentioned on BB, and that works well, as does new solder on an old relay. Reflowing the old solder does not seem to last, at least on the 4-5 I've tried it on.
What's the female equivalent to a dick pic? twat shot?
There isn't one because dudes aren't grossed out by unsolicited vaginas.
jerryc is offline   Reply With Quote
Old 05-22-2012, 07:37 PM   #4
Mr. V
Mr. V's Avatar
I have never had the ability to properly solder things, so I was happy to turn it over to a pro.
He "desoldered" the board to remove the relay for bench testing (it was OK), then quickly resoldered it.
He used some weird fabric looking stuff to "desolder," which I didn't understand at all.
Old 05-22-2012, 08:25 PM   #5
TrickMick
Broad Member
TrickMick's Avatar
http://www.radioshack.com/product/in...LAID=107594598
Old 05-22-2012, 09:58 PM   #6
jerryc
jerryc's Avatar
^ Yep that's the stuff, lots cheaper than a good 'solder sucker' and seems to work fine.
Old 05-23-2012, 08:23 AM   #7
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
desoldering is an either/or/both kinda thing. sometimes the braid works really well, sometimes the sucker works really well, and sometimes you get hosed up and have to fiddle with some combination of the two before ruining the pcb
Megasquirt Tuning!
Old 05-23-2012, 08:33 AM   #8
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
the relay is never bad, it just needs a new bead of solder laid on each contact. it's stupid simple.
don't want to do it yourself? ship it to me and i'll refurbish it for you.
sounds like another good article idea for me to write on the next one i do.
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 05-23-2012, 12:59 PM   #9
2manyturbos
That's good to know because I have a stack of the controllers that don't work. Probably, at least 10 of them. I'll fix them all at once. Marathon soldering adventure. BTW, I've fixed at least 10 clusters since your other article.
Old 05-23-2012, 01:13 PM   #10
Pro Sneaker Peddler
It's time for me to fix the cluster AND relay. Fuel gauge isn't working and sometimes when I turn on the HVAC fan the speedo drops or dies for a few minutes.
Same deal with every other relay in this damn 940.
