roflcopter
- Sep 30, 2013
- Lower Alabama
So I got everything sorted out on my brick, well not everything, but it runs!
Now I'm chasing down a few little issues while I wait a paycheck or two to register it(gotta love FL for that). Anyways... I've done some searching and fixed quite a few issues, but these are the ones still on the table:
Temp Gauge - doesn't work
Fuel Gauge - doesn't work
Now I'm pretty sure these worked when I very first picked up the car, but my memory is a bit hazy. Neither one works at all now, and after doing some searching it seems that there is supposed to either be a voltage regulator or normalizer of some sort behind those gauges that is known to fail. I had some issues finding information that pertained to a 1985 though, they seem to be a bit of a crossover year. Well lost story short, I see no board or box or anything behind those gauges. There is one circular plug with ~8 wires going into it on that side of the cluster, and one single wire that connects to a blade connector towards the bottom of the cluster. All the wires from both of those run directly to a wire loom that goes towards the firewall and the passenger side of the car. Any ideas?
Vacuum lines - lots of broken ones
Is there a post somewhere with some sort of list of necessary ones? I'd like to clean everything up and eliminate as much as possible without going racecar mode on it. Specifically there are two that come off the top of the throttle body, one small, one large, that run towards the drivers side headlight area under the air filter box. I assume these go to the charcoal canister, I also know I'm going to have a hard time finding something to fit the little, hard one. Are both necessary? I know I need to keep some negative pressure through there to help crank case gasses and all make their way through the box but are both needed?
Cruise control - no worky
Honestly haven't tried to diagnose this yet, but if there are typical failure modes somewhere I'd love to see them.
Brake failure light - constantly on
I replaced a shot master cylinder, rebuilt all the calipers, and fixed a few leaks. The master cylinder needs to be bench bled again I think though, pedal has very little feel and foot to the floor doesn't really stop the car all too quickly. Will bleeding the system again and hopefully making them work better fix the light as well? Do I need to look into proportioning valves as well? I know these cars are notoriously complicated when it comes to brakes.
Thanks all!
Thanks all!
