dobber13
- Nov 16, 2002
- elgin s.c. 29045
Is there someone in or around Columbia S.C. surrounding area that would be able to look at a problem I have. Running lean (I think) and I have tried and tested everything and haven't been able to figure out what is causing it. At Idle it pops out the exhaust as if it is missing but it's not electrical since I have ruled that out.I have gone through everything at least twice and no I can't find any vacuum leak. Parts I have changed fuel pump,intank pump and temp.sensor, 02sensor and cleaned CPR, fuel distributor and frequency valve, new air filter,fuel filter, intake manifold gasket,throttle body gasket,ACV hoses,intercooler hoses,all vac. lines.Tested fuel delivery,system pressure 80psi,control pressure 25 cold warm up 50psi ,rest pressure good. Compression 1.155 2.155 3.155 and 4.155 ,new plugs,wires,distributor cap, hall sensor and rotor.
This work has been over the last 1 1/2 years. Had alot of support from T.Ber's but couldn't find the problem. At this point another set of eye's on it would help.
