#1 | |
junkman
![]() I dragged home another car.
My first 122. 1966 b18 m40 car. Respray paint but seems to be holding on well and one color for the most part. Car has almost no rust. It sat for 5-8 years depending what story I want to go with from the PO poured some gas into the carb and it started up on the second try. so far I got "new" wheels and tires from Luke locking gas cap, filler neck seal, wiper blades, radiator cap and rear reflector from HiPerformance Auto changed oil (delo 15-40) and filter replaced clutch slave from IPD adjusted valves and added a cork gasket I drained the old gas - no rust inside the tank - thankfully Drove it today for about 3 miles high on the priority is to replace the exhaust - its all original and I only like the CO2 smell so much inside the cab one of the steering arm links is bent ![]() ![]() ![]() someone added a period correct hazard switch - the red lights up when hazards are on ![]() ![]() ![]() ![]() ![]() ![]() ![]() I also picked this up 65 122 from the local yard ![]()
85 245 | 82 242| 75 245| 69 145 |66 122| 67 220 ![]() Quote:
dude
![]() Get the sport exhaust it sounds good. Or just a 2" system.
junkman
#4 |
The Librarian
![]() Nice score(s). Do you plan to make them both run or is one a parts car?
That hazard switch might just be an original Volvo accessory. ![]() |
#5 |
junkman
#6 |
#7 |
![]() Nice car. Parts car doesn't look bad either.
#8 |
junkman
![]() parts car has a nicer interior then this car. still shot 50+ year old but the color is the same
as the stars get chipped this will forever be on the front page .... ![]() Last edited by Jack; 12-22-2016 at 04:39 PM.. |
#9 |
junkman
![]() new cat showed up at my house today... I woke up and she was just chilling next to me...
![]() I decided to clean out the interior a bit today and see the rust damage on the floor boards. It's a lot better then I expected, mostly surface rust with few holes. Should be fun to patch these. (pictures make it look worse then it actually is) Soaking the parts in Krud-Kutter Can someone tell me if the plastic parts were polished when new or were they always matt? ![]() before cleaning ![]() ![]() took out the crusty floor matt and started to peal off the sound deadening ![]() driver rear - has the worst rust. All the water would trapped under the floor matt and eventually found its way out. Thanks OBAMA ![]() passenger rear ![]() nothing like a wet dog smell, though I bet I just replaced that with wet horse smell. I will be removing the seatbelts and pressure washing them. One of the belts has a '68 date stamped on it, I bet a dog chewed up the original. ![]() Quick pressure washing to remove all the grime before I get in there to remove the rest of the sound deadening ![]() after pressure washing the dog out ![]() Im on the fence about the sound deadening material. The choice is between Lowe's Chepo roofing Peal n Seal or Dynamat. I have used both before, of course the dynamat is the way to go but expensive.... But Peal-n-Seal would be better then factory or nothing even... what do you think ? Last edited by Jack; 08-07-2018 at 07:22 PM.. |
#10 |
dude
![]() Id just throw the 240 sound deadener in there. They always rust in that back floor pan.
Those rubber floor mats never let the car breath so they rust. Cat. Use some #0000s steel wool on those chromepieces. Spraying some wd40 on there helps as well or after your done and wiping it off keep it nice for awhile. |
#11 | |
![]() Quote:
#12 |
![]() awesome looking project, congrats!
1988 745T http://forums.turbobricks.com/showthread.php?t=356096 1972 142S http://www.turbobricks.com/forums/sh...d.php?t=311926 1991 780 Sold 1979 244DL Sold 1986 740+T Sold 1983 242T Sold |
#13 |
![]() Company called FatMat works great!
#14 | |
junkman
![]() Quote:
thank you, you should buy it I already have a bunch of Dynamat and loved it on my 245 but like said both are expensive and PNS is cheap but not as effective - anything is better then no deadening decided to polish my knobs ![]() before ![]() 1/2 done ![]() with the lettering you have to cake on the paint, wait for it to dry and rub off the excess ![]() could be better but I'm done with these ![]() Last edited by Jack; 08-07-2018 at 07:43 PM.. |
#15 |
dude
![]() looks good
#16 |
junkman
![]() just small updates but very time consuming
polished one tail light and surround. Left the other one alone since it's broken. I wont install this one until I get new tail light gaskets from Eric ![]() ![]() ![]() someone tell me if that much gap on top and bottom grille is normal or what the story might be ![]() Decided to take the bumper off to tighten, straighten and clean it up. The driver side override was loose and would rattle all the time. It took a lot longer then it should have, bolts inside the overrides were unreachable so I cut them off and welded a bolt inside the bracket. Took me forever to get it back on since I had to loosen up the bumper brackets and then try to realign them. I also installed a late model license bracket to center the plate. before ![]() after ![]() I forgot to take a picture of the bolt welded inside this bracket. I also had to hammer it flat before that. ![]() ![]() Last edited by Jack; 08-07-2018 at 07:57 PM.. |
#17 |
The Librarian
![]() The gap at the top and bottom of the grille is a result of the center bar being pushed in. It's also why there's a gap between the hood and front panel.
This is how it should look. ![]() Thanks for fixing the license plate. It's a pet peeve of mine. They're either too high or too low without the bracket and just don't look right. |
#18 |
Bored Member
![]() What did you use to polish the knob?
That came out looking good.
just a bunch of bicycles and a 71 145 GT project + a 1982 Dodge Xplorer 221 |
#19 |
junkman
![]() ^ but nothing on the front panel is bent or damaged? It appears to be bent in pictures maybe but I checked and it's just a respray
I mounted the plate low also but to me it was also just a dumb. I did it for you Ian, you welcome ![]() Thank you. Just metal polishing compound on a buffing wheel, blue stuff called Blue Magic Metal Polishing Cream found just about everywhere. If I would have spent more time it would look brand new.... maybe when the rest of the interrior is done I'll go back Last edited by Jack; 08-07-2018 at 07:58 PM.. |
#20 |
junkman
![]() turns out my 122 has been out at night banging the local "ladies" and bringing them home
craigslist add Selling my 63 volvo wagon and all my spare parts. 2 extra parts cars, engines, transmissions, overdrive, doors, fenders, hoods, trunklids, boxes of emblems, switches. Ect. More than enough here to make a solid car with. Just don't have time to do it myself. Too many projects I just came back with all the "loose parts." Im going back for the cars next weekend 62 wagon - clean title, pink in hand but the previous owner never got it registered from the pre previous owner - signed 2012 the other two are coupes with no title but havent been registered in over 10 years. I need to write up a "statement of facts" for the dmv pictures to come when I drag them home.... BTW all but wagon will be for sale will probably keep the wagon - needs passenger side floor- its been cut out ![]() ![]() no engine - and trans tunnel has been cut out - very little rust in the floor driver door is fubar - but came with 4 extra ones ![]() this one has an efi b20 in it - no rust even in floors ![]() ![]() |
#21 |
dunning-krugersquirt
![]() Any chance there's a spare set of bumpers hiding somewhere in that pile?
#22 |
![]() Join Date: Oct 2004
![]() You are welcome Jack.
![]() Glad you were able to snag the piles!
RIP Doug Williams "Mr. Doug" 4/15/2009 Pete Fluitman "fivehundred" 7/14/2013 Mick Starkey "TrickMick" 1/10/14 Mark Baldwin "blue850t5" 7/19/18 Nick Fengler "fengler" 8/6/18 Thomas Fritz "stealthfti" 10/11/18 74 144 B20 http://forums.turbobricks.com/showthread.php?t=224983 90 745Ti http://forums.turbobricks.com/showthread.php?t=334698 If you need Superpro bushings PM me for price and availability! |
#23 |
junkman
#24 |
![]() Hey, I know when enough is enough, unlike you.
#25 |
![]() Wow you got the motherload!
