Powderminkey
- Oct 9, 2022
- UK
Hi all, I'm pretty new to Volvos so bear with me :0)
I'm trying to find some torque figures and get some advice regarding my
standard 240 axle (1030) non LSD diff 3.73ratio.
I need to pull the diff out and replace or at least check my side gear thrust washers. And before I start pulling it all apart I need to know what torque settings I need to use for my main bearing caps and probably the ring gear bolts.
Am I right in thinking I will have to remove the ring gear to get the pin out that holds the top and bottom spider gears out so I can then pull the side gears?
Do I have to use new bolts and reset the shims if the ring gear is removed bearing in mind that part of my axle is set up sweet?
I've spent time trying to find the answers on here already but most seem to be talking about lsd swaps. I found these but wouldn't mind either confirmation or correcting before I screw it up
Main caps 35-50 lbs/ft or 60lbs/ft (unsure if either are correct)
Ring gear 50-58lbs/ft or 65-80lbs/ft if the bolts have a flange head.
They could be totally wrong though.
Any advice will be graciously accepted
Cheers
Matty
Cheers
Matty
