Boosted2003
- Jan 14, 2003
- Cocoa/Pensacola, Florida
Damn It People You Can Get Them From The Volvo Dealership.....
guidom12345 said:53.4465 Is the volvo part number for the manifold. My dealer wouldnt sell it to me. Some have said their dealer will. Let us know if you find a place that will order it in the US (dealer, or whoever)
The oil feed and return wont be too hard. Right now the housing is clocked about 45 degrees which seems like too much. It wont be that hard to run lines to it when it is oriented vertically.
I would like to fit an internal gate if possible. However, the t4 housing is pretty fat and I dont know if i can get a diaphram in between the housing and the block. I am open for suggestions. I have some engineering to do there. That would also require tracking down a stage 3 internal gate turbine housing. I might try to put an external on still. Let me know which gates you suggest and where you propose I should put it. The best place looks to be at the collector right above the turbo flange. However, I am reluctant to cut into a 300$ manifold.
guidom12345 said:3514465 is the Volvo part number. 312$ from volvo. I guess it is that easy. Now there are no excuses against going 16v.
BTW I sell 16v heads so if anybody wants one let me know. I have several for sale right now.
Morley said:Will this setup fit inside a 240? I installed a T3/T4 hybrid today on a 8V, and I have like 2cm to the wall...
Long story behind the t3/t4. It is brand new and I paid too much for it. My turboford buddy suggested the 50trim compressor was good for an 2.3 8v application. We'll see how it works. I ran a 16g for a while (now dfer 10 has it), but i wanted to go even further off the deep-end. Why not?
The header is for the italian market b204. (16v turbo)
I have a bunch of pics, but here are just a few. The original plan was to go with the b234 block, but now I am going b230 block for several reasons. I have a VW timing belt tensioner from a 1990 GTI 16v on order. This is a timing belt from a 1994 hyundai sonata v6. (it fits the gears perfectly. I have the 16v crank gear and a 3rd 16v cam gear as the auxillary gear application on the 8v.). The turbo is a t3/t4. Stage 3 turbine with .63 A/R housing. Cold side is 50 trim wheel with .50 A/R housing. Other compressor is stock t3 .48 A/R housing.
I want some other tbrickers to go 16v too!! I know you LA guys can get the heads cheap, if you dont have them already.
Thinking about engine swap for 262 coupe. I have considered everything from a 240t all the way to a s80, after reading some posts I'am starting to lean toward a b234 turbo. I have not seen any real numbers but iam hoping for ~300hp and Nor Cal smog legal. any info you can provide would be great. Also, what did you mean about LA guys getting heads cheap, i live in Nor Cal, does that apply to me also? Thanks for all your Help,,,,,,,
like I said earlier...CA + 16v + turbo = illegal converion, won't pass unless you "know" somebody or have a '75 or earlier car
northern california...start hitting the pick-n-pulls for heads, just be wary of motors with broken timing belts, good chance the valves and pistons met at a high rate of speed....I've seen complete running 16v cars for sale on craigslist for less than a grand....pull motor, part out car or ??
