16v questions
bikeidaho
How possible is it to convert a 1981 245 2.1 to a 16v? Is it possible? Anyone done it? I wanted to do it to my 2.3 but I got rid of it so now the project car is a 2.1. Should I just turbo it? I really want a 16v though...
Gofast
Norway
Convert 2.1 into 16v? If I'm understanding you right you want to fit a 16v head to the B21? It is possible! But not a straight swap. The block (and maybe the head, I don't know... :e-shrug: ) needs to be modified. I do know it's been done many times both in Norway and Sweden. But it's not worth it if you're asking me. Unless you're building a serious racecar... :badboy:
MikeHardy
The Sirius/Nova Police
northern Wales, UK
i had a look at dan's 16valve head pics and it looks like the combustion chamber matches the bore for the 2.3engine. so might not be sutible for a 2.1. maybe using a B204FT head which i assume as a smaller combustion chamber
Oskari
Blaah.
Finland
You are right, b234 head requires 96mm piston.
lilpaz
USA
So what if you just bore out the B21 block to 96mm? Technically wouldn't that fix the combustion chamber to cylinder bore problem?
nohbudi
Jesus Christ...
Toledo, OH
it could, and at the same time it could trash your cylinder walls, and end up with premature water jacket failure.... the cylinder walls on the b21 block are just too thin.
Oskari
Blaah.
Finland
You based this statment on what?
lilpaz
USA
But...there have been people who have bored out their B21 blocks out that much with no problem right? So it's just luck...
towerymt
the real Towery
VA, USA
That's wrong without further qualification. A B21 can and has been safely bored to 96mm. However, not every B21 can be safely overbored that much.
If the block is not checked for wall thickness, THEN it would be luck...
G
Guest
Guest
i have an extra b21ft in a parts car that i have been thinking about boring over to put b23ft pistons in. the engine would be a 16V turbo of course... what is the general idea of the min. wall thickness for a HO turbo engine?
didn't IPD used to sell a big-bore kit for the b21s?
Oskari
Blaah.
Finland
Copy and paste from our Finnish Volvolandia board:
" B21=2.35mm
B19=2.1mm
B19SN=2.9mm
B23 =3.6mm "
Those are wall thicknes figures, when each are borred to 96,01mm (b23 standard)
Written by Finnish machinist J. Hiipakka.
dl242gt
The world of the smiling Dogo
S NJ, a suburb of Phila.
I've thought about doing this also. However, it's just so much easier
to get a 2.3 here in the US. So, why fight it? Just get yourself the
bigger motor because it's going to make more power and it won't
really cost any more to do. In fact if you get a B23FT or B230FT it'll
already have pistons you could use. Just have to get valve reliefs
machined into them.
B214FT does sound cool, but...
TDi244
near dc
True that. Any advantage of having one block compared to another? For example, could the b21 rev a bit higher due to less piston mass? Or is the speed limit the valvetrain, etc? Slightly off topic I know... :x:
Edited for... I read somewhere that the b21 block is a thicker casting, as well as the b23ft. How do they compare to the b234?
A
Anonymous
Guest
First of all: the b234 head does NOT need 96mm pistons, but 94mm...
BUT
i can't see why you all have to try forcing the heads on old bXX-series blocks. :rant:
the b234 block is from all points of view superior to the old bXX blocks. and why do you think they put an external oil pump on it? yes, to feed 16v head :roll: and if the crank (which i look upon as being the weakest part of the engine) doesn't meet your requirements you can always do a few small modifications to fit a bXX crank. Stock b2X4 cranks will withstand at least 700hp. the newer blocks also have pistons that are able to handle LOTS of more power than the old cast and hypertheuntic pistons of the bXX engines. There are b234 turbo engines running stock pistons with over 500hp in sweden. some even claim that they can withstand more power than the forged ones of the b23et.
//tobias -- finland
