The Full Banana
Drive, Revive, Tinker
- Apr 15, 2007
- Lake Mills, WI, USA
Check it out on YouTube:
www.youtube.com
A brief history, linked to posts in thread:
Building your own 240 T5? This might help:
Volvo 242 with T5 engine swap
Videos showcasing my 1980 Volvo 242 GT with a b5234t T5 engine swap, Getrag transmission, Porsche brakes, and more.
- 2013: Acquired as rolling shell; build begins
- 2014: 4 cyl B230FT swap complete; epic cross-country roadtrip
- 2015: Carefree driving & car shows; 246whp dyno (full specs noted in post)
- 2016: 5 cyl turbo engine swap
- 2017: Cautious driving & diagnosing oil consumption
- 2018: Head replaced; still diagnosing oil consumption
- 2019: Block replaced with forged block build; engine bay repaint
- 2020: Block rebuilt with oversized pistons; fab new exhaust; upgrade to E85 & Gaz dampers
- 2021: Week of bliss after dyno tuning to 366whp; followed by months of no-start, then a little driving
- 2022: Freak oil starvation incident damages bottom-end shortly after recovering from no-start issue
- 2023: Occasional driving until continually decreasing oil pressure prevented use
- 2024: Crank & bearings replaced; MaxxECU swap
- 2025: Head gasket blew then replaced after first drive; 8” round headlights installed
- 2026: Full color change repaint to GM Supersonic Blue
Current 5 Cyl Setup (2016+)
- Engine
- '99 S70 T5 (B5234T) block with crankcase windows & liners shimmed
- Wiseco 81.5mm pistons & rings
- Maxspeeding 139.5mm H-beam rods
- '98 850 T5 (B5234T) head lightly ported
- NA cams (timing: intake 7 deg ret. & exhaust 5 deg adv.)
- 960 oil pan & transfer tube shortened & rewelded in middle; 10an & 1/8NPT ports welded on for turbo drain & oil temp
- '07 S60R intake manifold w/ plenum shortened to clear PS pump
- '07 S60R ethrottle valve
- Saab ethrottle pedal (Hella 6PV 010 946-141)
- Modified S70 fuel rail (machined for factory FPR, bungs welded on for 6AN inlet & 1/8NPT pressure sender)
- '98 850 T5 (B5234T) 3 bar FPR
- ATP C30 cast exhaust manifold ceramic coated with Cerakote Air Cure
- Turbosmart 38mm external wastegate
- Garrett GTX3067R with ceramic coated .82 A/R turbine housing
- CX Racing Evo VIII intercooler (32"x12.5"x3.5" with 2.5" inlet/outlet)
- Gates Racing kevlar timing belt
- Volvo 260 Diesel passenger side engine mounts on one-off brackets
- S60 PWM cooling fan
- Full 3" TIG welded 304SS exhaust with a cat and 2 Vibrant mufflers
- 92+ 940 NA radiator
- Mann Provent oil separator (returns to pre-turbo intake pipe; drains to oil pan with check valve)
- Bosch FR7DPP+ spark plugs
- Engine Management
- MaxxECU Race with lambda, knock, and EGT monitoring built in. Custom wiring harness.
- Previously: MS3x w/ knock module, 4 bar MAP, dual VR conditioner added in
- Driveline
- Getrag 265 5 speed manual transmission w/ removable bellhousing
- Volvo 960 bellhousing from auto trans
- One-off adapter plate connecting trans & bellhousing
- e46 M3 rubber transmission mounts
- Sachs 240mm full-faced clutch disc from BMW e34 M5
- e36 M3 / e34 M5 giubo
- lengthened m47 front driveshaft
- 940 driveshaft support bushing with j9fab bracket
- modified getrag 265 shifter bracket mounted with e46 m3 trans mount
- garagistic DIY shift selector, shift selector joint & tall shift lever
- Tilton 60-1100 hydraulic release bearing
- Suspension
- Front
- GAZ Gold coilovers + 336lb x 8" main springs & 6" helper springs
- Homerbuchka camber plates
- Control arms boxed with Yoshifab plates fitted with STS Machining delrin bushings
- Kaplhenke V2 QSRC spacers with adjustable Ackerman
- GT firewall braces
- cravingboost big strut brace
- iPd lower chassis braces
- STS Machining 28mm drop swaybar
- Rear
- Shortened trailing arms (20mm shorter)
- Speedway 5" adjustable spring perches
- 200lb x 5" x 9.5" main springs
- Gaz adjustable shocks, 40mm shorter
- factory rear swaybar
- Kaplhenke hybrid torque rods with Volvo bushings
- iPd adjustable panhard bar
- Genuine Volvo front trailing arm bushings
- Kaplhenke spherical rear trailing arm bushings
- Brakes
- S60R front & rear rotors (330mm)
- '05 Porsche Cayenne V8 front calipers (6 piston)
- Homer's caliper & brake line adapter kit
- iPd braided stainless 240 brake lines
- Bosch Quietcast pads
- '94 Ford Mustang Master Cylinder w/ 240 reservoir
- Wheel/Tires
- BBS RC305 17x9 et32 w/ motorsporttech adapters (38mm front, 32mm rear) w/ 245/40R17 Pirelli P Zero Nero GT
- Interior
- Recaro LS-B seats from mkII VW reupholstered in black leather with new bolster foam
- GT door cards
- Flocked 1987 240 dash
- Momo 360mm leather steering wheel & horn pad a la Volvo R-Sport on Momo hub with 2.5” spacer
- Rattletrap (sound deadener) below 1/8" closed-cell foam (decoupler) below 1lb/sq ft mass-loaded vinyl (sound barrier) below factory black carpet
- Exterior
- 7" round H4 ecodes with 12 gauge harness powered by high & low relays in sealed relay box
- GT fogs with 12 gauge harness and 100w bulbs powered by relay in sealed relay box
