RollinRoland
- Jul 12, 2020
Hi all;
Been a member for a while but this is my first time posting. I am looking to see if anyone has any advise on what might be wrong with my 81 B21f k-jet m46 244.
Background:
This car was my primary daily driver for about 2 years. I trailered it across the country due to a move and it sat for about 3 months. I never had an issue with the car other than an occasional rough start in the winter. I started driving the car daily again until one day I had driven it on the interstate for about 40 minutes and noticed it was idling high when I was on the clutch or in neutral. I pressed in on the throttle and it seemed to stop. When I started the car after running into a store, the problem was gone. When I got back home, it started idling high again. The next day, it started fine but began to idle high once it got to temperature. I've tried quite a few things to fix this but was hoping someone might be able to point me in the right direction. It idles at around 3k-4k rpm.
What I've tried so far:
Replaced IAC (I have 5 of them -same issue with all)
Checked Throttle Position micro-switch with ohmmeter (no issues)
Hooked up smoke machine (no vacuum leaks)
Took off throttle body/cleaned/replaced gasket
Cleaned flame trap
Checked all grounds
Checked connections to ECM from IAC/throttle switch
Re-wired all terrible decomposed wires
Set idle with IAC unplugged
-Will replace coolant sensor (fuel injection) on Monday when the sensor is delivered. Pulled the old one, it looks rough.
Things to consider:
The idle does go down when I pinch the vacuum hose on the IAC
I got gas at Walmart (for the first time ever in this car) right before this started happening
I had the heater on when this started happening (happens with it off as well)
I appreciate any help offered!
Background:
Cleaned flame trap
Checked all grounds
Things to consider:
