vcolper
- May 4, 2008
- North Port, FL
My 1984 242 Turbo started misfiring after replacing vacuum hoses, engine harness and cleaning regulator (CPR).
This car has been a nightmare (still love it though). Since I purchased it i've been fixing just about everything.
First thing was a bad fuel pump relay. The previous owner would jump the relay contacts to use it. -fixed-
It idled at 1500-1800. The idle bypass valve hose was not connected. they plugged the hose inlet. -fixed-
Fuse #13 was bad so the idle control was not helping either. -fixed-
The car would not accelerate good. It barely reaches 55mph
Found a wrong fuel pump with no check valve. -fixed-
Then he started running much better, but starting became an issue. I would have to try about 20-25 time for it to start. once warm it starts and ran ok. I always noticed the vacuum gauge close to the yellow(not much vacuum) so i decided to replace all the vacuum hoses.
I discovered the flame trap was disconnected from the elbow on the turbos inlet side. It was plugged. Mess of oil all over the engine on driver side. -fixed-
The wiring harness was a mess with splices all over so I also replaced it at the same time I replaced the vacuum hoses. I also cleaned the pressure regulator replaced the injector o rings.
The car started up immediately. I was impressed. It idled nice and accelerated (in neutral nicely). vacuum gauge was much better on the dark side (hi vac). So I decided to try her on the road. Put it in Drive, accelerated and the engine dies. It feels like its being flooded.
I checked the injectors and two atomize the fuel perfectly, the other two, fuel just prays out in an uneven pattern. Tried cleaning them, still uneven spray pattern. and the car dies upon acceleration. I played with the fuel mixture now it idles ruff.
Any suggestions?
Any suggestions?
