everyhumanvovo
- May 4, 2009
Have an 87 240 manual which if I recall when installed in 2010 had a slightly different cruise setup than other years of its vintage. It has been rather intermittant in function last couple of years. Some days it will set a speed, some not. Sometimes it lets go of set speed. Finally, hasn't worked at all for a couple months.
Had installed with NOS switch/stalk, and rest of system was used parts. It worked well for a few years. Started couple years ago with some days it worked, some not at all. Or, some days it would start working after several re-starts/attempts. Normally, if it did start working, it worked for rest of day, mostly.
Likely, not stalk switch as that is least used. Thinking may be vacuum issue, but I think hoses look alright. Does not seem related to environmental conditions; possibly works less often in hot weather. Two months back, it didn't work on 90 mile trip at all with about 50 attempts to set the speed, but, then worked all the way back without issue. Any insights much appreciated!
