Girling front calipers, ATE rear. Replaced Master Cylinder and all hoses. Bench bled master, though air may have been introduced as we were doing the initial bleed (conventional two person operation) that revealed ruptured hose. Left rear caliper not getting fluid. Fluid present at intake of rear brake valve, but not after. Bled using an air compressor at low pressure (18PSI) and with an oil/water filter fitted to brake reservoir. Incidentally right rear caliper seems to be leaking, rebuild kits ordered, doing both at the same time for good measure. Does not seem to hold a bleed, last night I thought I had good enough pressure to drive it, but not this morning.
Question 1: Is my diagnosis that I need a new rear brake proportioning valve correct? Or would there be another reason fluid is not getting past it?
Question 2: Should these also be replaced in pairs? Wow they are pricey......
Question 3: Could it also be the pressure sensor?
