Finnish240
- May 6, 2011
- Finland
In 2009 my dad bought this car for me to be my first car. Soon I realized that it had too little power. Since then I was searchin +T it. Car had B200F and M47 in it, so in Finland it is noGo for turbo it with original block.
Here is how the ''Old thirsty lady'' sits right now.
Specs
Rebuilt '90 B230FT ''K'' block From 740
Mitsubishi 18t turbo
Big Green injectors from Bosch
New style oem exhaust header
V cam
Self made 3 to 2,5'' exhaust With two mufflers
Walbro 450 e85 fuel pump
M47 and stock clutch
-45/35mm lowering springs and shocks by Lesj?fors/GTS Performance
Upper and lower GT bars & Strut bar
Dual 19mm sways at front
Dual sways rear
300mm front discs
Clear lenses for blinkers, from Hova.com
Volvo 15''x 5,5'' wheels with 195/65r15 tires
Whole car is built as budget allows me to do, so everything that can be made by myself is done as it as I can at the moment. This car is kinda learning process and having fun with cars for me.
So last summer after long four years I found a bargain block with lots and lots miles on it from southern Finland. I was searching block with squirters, but I thought that this is good opportunity to start turbo project and I can find newer block after. I drove head to the machine shop, and assembled rest of the engine with new bearings and seals. I had an issue with engine at the first few miles with it. Oil pump seal from it's pipe popped and caused some flickering at oil pressure warning light. I took the engine off, checked it and resealed the pump.
Currently it is like ordinary b230ft- engine with A-cam. So it is quicker than it was when I got the car but nothing special
Sorry for the huge pictures
Specs
V cam
Dual sways rear
300mm front discs
