1991 740 pickup LR4 V8/4L60e Swap
Nice work as usual.... any recommendations for MIG welding of SS pipe? I did the system on my Cheap Thrills Sedan, just can recall that another inert gas was recommended as well as the special wire. My Millermatic 175 had no problem welding those thin wall pipes, but the welds were butt ugly. Given your background & experience, I'm betting you know the preferred method.
When is that LS conversion coming?
Hello! I only ever TIG SS piping, so unfortunately I can't offer any advice on using the MIG. It's been over a year since I did any TIG work, so my welds aren't pretty - also I find it MUCH easier to butt-weld piping vs. overlap. The pipes I bought are designed to be slid over, so I'm getting practice on that. My problem is that I can run out of patience, and then I just forget to keep the tip clean & end up with messier welds - so I'm also working on being more patient, and grinding the tungsten more often.
The LS. At this point, I'nm doing the short block in the old 240 first, should be in the next week or so - once that is gone, I'm bringing the truck back in to remove the Volvo drivetrain. I'm assuming I'll be done in time fro Carlisle Import Show, I certainly hope so anyway.
More work on the exhaust today, the details are taking longer to resolve than I anticipated - getting the hangers and muffler / pipe offset just so has been laborious, however I don't want to hear any knocks or rattles, so it is what it is
Worked on the rear muffler suspension first. Shaped an SS pin to conform to the backside inner of the muffler, drilled the spare well & made a tie plate with M8 pins to bolt it in place
index.php
Bent, cut & welded a pin to the muffler
index.php
The muffler is heavy, and since the hangers are diagonally opposite, I'm adding a third at the back to keep it balanced evenly
index.php
OEM Volvo Trailer hitch installed at this point - to make sure the exhaust clears. Have to mod the rear valance & reinstall, after I fix a couple of mount points
index.php
Had to tap the captive nuts first
index.php
Had to dig through my Volvo hardware to find 8 suitable length M12x1.75 bolts - the frame rail is relatively shallow - so they have to be just long enough to properly anchor the hitch
index.php
index.php
Rear muffler clearance off the floor is good
index.php
Made a hanger mount to replace the factory inboard muffler hanger, bent & welded a pin to the resonator . May or may not need to add an outer.
index.php
More exhaust work - finally getting close to completion of the rear half
Made a hanger for the forward outer hanger - the plate is cut from a X1/9 bumper bracket, had the same bolt spacing
index.php
index.php
Made a tie plate for the rearmost muffler hanger set through from the cargo floor
index.php
After several removals & refitting, I got the exhaust cut to the correct length to allow space for the muffler VBand - tacked here
index.php
Still have to seam weld this
index.php
Tailpipe tacked
index.php
welded
index.php
for the VBand, the exhaust, although spec'd at 2.5", it's actually slighter over, so I had to make a narrow spacer sleeve to make sure the vBand were properly aligned with the pipes
index.php
index.php
index.php
Sleeve tacked so it doesn't potentially rattle DTR
index.php
index.php
Hopefully wrap this up in the AM
index.php
Hitch spec plate 6820185 - 2" ball
index.php
Hitch pin needs to be over 4" If I can't locate one, I'll drill this bar stock for a clevis pin
index.php
index.php
Modified the rear valance for the hitch, and made a 9/16" x 4.25" hitch pin
index.php
index.php
index.php
cutting the valance - I had marked & worked out from the center, but it's actually offset :(
index.php
index.php
index.php
Cut too much off the left side due to measuring from center (above)
index.php
original attachments still accessible (somewhat)
index.php
index.php
Re-drilled this one to the left side
index.php
After that, I fifnshed up the exhaust welding & install
bridge section to join old exhaust (that will go away with V8) with new exhaust
index.php
overlap welds getting cleaner
index.php
all installed & aligned nicely
index.php
index.php
index.php
index.php
Reattached the handbrake, and put the console back together
index.php
spare & jack holder back in
index.php
Going back in time - I had questions about wiring the PNP range switch
index.php
- Brendon from LT1swap.com found the wiring diagram I needed to know to figure out which wires go where. 4, 5, 6, 7, 8 are what I need from the above connector
Looked at the range switch wiring again - I believe I will need all 9 wires - the 5 range wires, then the other 4 are for reverse lights and start inhibitor
index.php
index.php
Just to update this so I don't lose track - I determined the interface wiring with the Volvo harness
OK. Driveshaft mods under way.
Ford Sport Trac 8.8 3:73 LSD rear ordered Griffin bracket kit, ordered. That will be for DTR - the conversion has already been delayed numerous times, so once I get the factory drivetrain pulled (looking at beginning of March) - I don't want more delays.
I'm going to separate the engine /trans & fix the trans harness plug leak, bought a kit for that. While it's apart, I'll do the F&R tranny seals.
I have a BTR torque cam kit. rear main, front cover, crank damper, etc., to all go in before I place it in the body, so ideally, I'll get that squared away in the next couple weeks.
Also have a few rust areas in the nose/battery tray areas to address while I'll have access. Also planning on making the headlamp sections detachable panels for more room. I saw someone with a later V90 make it a one piece removal, but those don't have the removable fiber center panel.
I'm kinda sick today, so I took the time to index/summarize the thread in the first post.
Nice! Width correct for the 7/9 ? Planning to adapt the Ovlov brakes or run the Fords' out back?
It's useable width - I'm not going to shorten the left to center the diff - I have had advice that on a 700 it's better to work with the diff offset. No issues with the caliper clearance off the frame rails that way. I haven't made any decisions on rear brakes yet. I think I want something a little larger than the Volvo. Prolly look through the Ford offerings. The 2014 Mustang caliper I used on the 280Z have handbrake levers, but so do P1's. I'll have to do research on that - I want a working handbrake.
I ordered a 1310 2-2-1379 flange yoke to be able to convert the Volvo DS to the Ford rear, using the stock size UJoint (1220786, for 3.5" yoke)
index.php
Giffin brackets for Ford8.8-into 700/900 arrived. Panhard rod standoff seems kinda sloppy, I may want top tidy up the welds/finish. No question it's functional though.
Been working on a 940 this week. Leaks all over.
Rear main.
Trans mount
Trans pan & filter
Downpipe O2 bung
Broken hot side stud
Fuel pump & filter mount
DS carrier & bearing
Water Pump & Radiator
AC condensor
index.php
index.php
index.php
index.php
index.php
index.php
Flywheel orientation @ TDC
index.php
index.php
index.php
index.php
last one in here threw away the shields
index.php
index.php
Found a shield on a trans output flange that has the same ID as the DS shaft - ground down the OD to clear the rubber & pressed it in
index.php
index.php
The last one in here decided a glove was the way to secure the fuel filer in place
index.php
Replaced the feed line with proper sleeved Volvo line
index.php
index.php
Fabricated new mount plate & filter bracket
index.php
index.php
index.php
back on the car
index.php
index.php
Volvo pump with integrated weep tank
index.php
index.php
index.php
index.php
