- May 3, 2010
- LFK
A chip in my windshield finally split so I cut it out and replaced it with Fuyao aftermarket, the glass was $119. It actually looks really good optically (distortion is a common problem with aftermarket windshields).
What are WOT AFRs now? Just realized I never asked...
Superb stuff. That V90 armrest is a nice find, I've been on the hunt with no luck. Have you considered a snow cap (3529534) on the cowl vent? It's easy to obtain a glass fiber replica these days. Finishing the look with some 18x6mm plastic honeycomb mesh will protect from debris and has a nice factory job look.
Great build! My 940 turbo has high miles but I?ve been following a similar route, 16t and all, so it will be exciting to follow along
Thank you! Mine is over 240k now, but the compression tests well so hopefully it still has plenty of life left in the engine. I would like to find a longblock to build up on a stand so I have a solid engine ready when/if the time comes.
I?m much higher at 336k, and while I have really great PCV, I need to run a leak down test during my next oil change to make sure everything is in order. It would suck to toss a bigger turbo on only to blow my head gasket a few miles later
