TerraceRacingDevelopment
- Nov 17, 2022
This is my first post here so let me know if I'm in the wrong section or something.
Me and some friend bought a 1988 Volvo 244 "rally car" to fix up and race. We got the car running but are having trouble with it trying to blow up once it gets to around 3500 in neutral or 2500 under load. It backfires like crazy at those RPMs and we think it is because it is running very lean at that point. Fuel pumps, fuel pressure, and fuel relay are all good (fixed or replaced). The wiring is all hardwired ie. rewired by someone with minimal electrical knowledge and reuses bits and pieces of the OEM harness. We think the car came Na and had a turbo added on by a previous owner, it also is supposedly re-tuned for 91 octanes.
UNKNOWNS
-What tune is on it (what it all does)?
-Are fuel injectors also tuned?
-If it has an ignition ballast/resistor
-If MAF is bad or just everything in the car
-The best way to check for a vacuum leak
KNOWNS
-Fuel pumps are good
-Spark plugs/coil good
-Fuel pressure is good
-Has replacement 200cc 16 ohm (low impedance) injectors
-Has some pressure in crankcase (We think PCV is somewhat clogged)
QUESTIONS
-If the ballast is supposed to be at the passenger side between the firewall and strut tower and we can't find it. What wires should be going to it in case it was moved?
-Is there a tune that would change the injectors currently in it so they can pump out enough for a turbo? (Turbo OEM needs 320 I think) Would that also change them from needing a ballast?
-Could a clogged PCV cause it to lean out so much at 2500 under load??
-Out hall sensor looks alright but it was ducttaped together a little bit... Could that be a reason why it leans out?
-Any ideas on anything?
UNKNOWNS
KNOWNS
QUESTIONS
