bobxyz
- Aug 29, 2014
- Boulder CO
I think you're OK with your turbo '518 LH2.2 ECU, your turbo '012 EZ117, and the '124 ignition module. I couldn't find a write-up on converting a EZ116K harness to EZ117K, so I wrote up the below info. Let me know if you try it and how it works out. Better still, take some pictures and add the info to the older conversion thread.
Normally, a 740 EZ117K sub-harness from a LH2.2 740 is used to convert a 240 from Chrysler to EZK ignition - see: http://forums.turbobricks.com/showthread.php?t=129382
If a 740 LH2.2 donor harness isn't available, it should be possible to re-pin a more recent EZ116K harness from a LH2.4 740 instead. I haven't tried this myself, so buyer beware.
How to change a 740 EZ116K (LH2.4) sub-harness to a EZ117K (LH2.2) harness for Chrysler to EZ117K ignition conversion
Untape and open up the 25-pin EZK connector - picture shows probing a pin, not pin removal (which is done from the connector face)
To easily remove the pins without damage, you'll need a pin removal tool - just a simple single thin rectangular blade one is fine. You might get away with a flattened paperclip end, or a "T-pin" if you're broke and really desperate.
In listed order, de-pin or move the below pins/wires from the EZ116K connector. Go by the pin number if the wire colors don't match (but post a followup first).
de-pin 1 YEL-RED diag box
de-pin 3 BRN-WHT CEL
de-pin 5 BRN battery +12v
de-pin 14 BLK ground
de-pin 15 RED-GRN EGR
de-pin 22 YEL-BLK EGR Temp
move pin 2 RED-BLK to pin 15
move pin 4 GRY-RED to pin 9 on cars with A/C; on cars without A/C, just de-pin it
move pin 10 RED to pin 4 (may need to cut back hall cable insulation to free up wire length)
move pin 11 BLK to pin 10
move pin 23 BLU to pin 24
When done, you should have the below pinout, which matchs the pins/colors in the main EZ117K conversion thread:
1 NC
2 NC
3 NC
4 RED hall sensor "+"
5 NC
6 BLU switched +12v (also positive terminal on coil, and powerstage pin 4)
7 ORG TPS 3 idle sw
8 YEL load signal from LH2.2 ECU-24
9 GRY-RED A/C compressor on (if you have A/C, empty otherwise)
10 BLK hall sensor "-" (this wire is the bare braided shield on the hall cable run through black heatshrink)
11 NC
12 BLK knock sensor (this wire is the bare braided shield on the knock cable run through black heatshrink)
13 GRN knock sensor
14 NC
15 RED-BLK knock signal to LH2.2 ECU-12
16 GRY (may change to thick BLK wire) spark signal to powerstage pin 5
17 YEL-GRY rpm out to LH2.2 ECU-1
18 NC
19 NC
20 BRN ground to intake manifold (and powerstage pin 2)
21 NC
22 NC
23 NC
24 BLU hall sensor "O" signal
25 NC
Copied from conversion thread:
1 NC
2 NC
3 NC
5 NC
7 ORG TPS 3 idle sw
11 NC
13 GRN knock sensor
14 NC
18 NC
19 NC
21 NC
22 NC
23 NC
25 NC
