Finnish240
- May 6, 2011
- Finland
So I got this 1999 B5244T V70 and I've got problem to start it. Sometimes with cold engine it cranks but it doesn't fire up. If i do 3-6 starts eventually it starts like there is no problem at all. When it starts, starting period is normal length. And every time it has started it works just fine.
No codes with cheapo OBD II diagnostic tool or fault light gloving whatsoever.
I did change cranckshaft sensor. Fuel pump burrs same way as it has been doing for a year when I turn the key. Today last time when it did that, pump did pressure every time when I turned the key. Normally it doesn't. Bad fuel pump?
