Pietercc
- Apr 5, 2019
- Stockton,CA
Thats premium where I am, so that should be fine.Good to know. I'm a mechanic by trade so I know some tricks to getting autos to mate back up. Can I just run 91/92?
91/92 works fine for a +T, just listen for knock and be careful when increasing boost above stock.Good to know. I'm a mechanic by trade so I know some tricks to getting autos to mate back up. Can I just run 91/92?
I never found one, you honestly may be better off just swaping the whole chassis harness. You will spend as much time cutting the harness as you would swapping everything, since they are similar enough cars. Otherwise get the wiring diagrams and start cutting. The harness will have dozens of wires to take out, going through multiple main connectors, both under the dash and in the engine bay.Is there any good threads on making lh2.4 harnesses?
oh okay yeah I can do that too. Will I have to pull the dash at all? I heard they're a PITA to remove.I never found one, you honestly may be better off just swaping the whole chassis harness. You will spend as much time cutting the harness as you would swapping everything, since they are similar enough cars. Otherwise get the wiring diagrams and start cutting. The harness will have dozens of wires to take out, going through multiple main connectors, both under the dash and in the engine bay.
I'm sure you wouldn't need too, though I would. The 740 wouldn't be too bad, but I think the 940 one is harder to remove. I've taken multiple 700 series dashes out, only takes an hour if you move fast, a couple if you're learningoh okay yeah I can do that too. Will I have to pull the dash at all? I heard they're a PITA to remove.
Yes but damn they replaced the pump on the new engine, I think I'll steal all the nice new lines too.Does your AC work?
Looks like the parts car already has r134.
at this point you're gonna swap everything
Okay thats true. I was also thinking of just cutting the parts car harness right where it goes into the firewall and then going from there on my own in terms of custom harness. I'd ideally like it standalone with just the two computers behind the glovebox. It doesn't seam like a crazy amount of work either. Just splice into my existing harness when it's needed. Just an option still though.Yes, you need to remove the dash because the entire harness is attached to the bottom side of the dash. Swapping the car over from Regina to LH 2.4 won't be too bad if you just swap the entire dash harness and the two harness that run down the sides of the engine compartment.
What you are describing is a 240 2.4 harness. It's already standalone, drill one extra hole through the firewall, and then everything runs perfectly into the glovebox.Yes but damn they replaced the pump on the new engine, I think I'll steal all the nice new lines too.
right you guys were mentioning that. I don't have any parts 240 around me so I figured I'd just use the wiring in my parts 940 car. I don't mind just extending 40 or so wires and making a few connections to my harness.What you are describing is a 240 2.4 harness. It's already standalone, drill one extra hole through the firewall, and then everything runs perfectly into the glovebox.
You will definitely be taking the long way home. The cars are essentially the same with the exception of the injection system. You could likely swap the harnesses all over in one day. You're not going to merge two different harnesses anywhere near that quickly. When you see how the ignition and fuel systems communicate with each other swapping the entire harness set up will become the obvious choice.right you guys were mentioning that. I don't have any parts 240 around me so I figured I'd just use the wiring in my parts 940 car. I don't mind just extending 40 or so wires and making a few connections to my harness.
I still might try and reuse my regina harness, I was discussing this in that other thread the other day and it seems promising.
