Group A
240 Ninja
- Sep 28, 2004
- Portland, Oregon
We did a B230FT and LH 2.4 swap on a 80 262 Bertone (k-jet V6).
Engine harness is from an 89 240.
Motor and ECU's are from a stock 92 940T.
M46 trans with stock lh2.4 dogdish flywheel.
Head was rebuilt, shaved and ported lightly.
RSI Stage 1 cam.
RSI adjustable cam gear.
Car runs and drives beautifully except for the below idle problem.
Problem we are having is it will idle at 1300-1500rpm after driving it and revving it to approx 6000rpm.
Idle is set to 900rpm. Idles fine during cold, warm, hot and after free revving up to 6000rpm. Always drops back to 900rpm. UNTIL you drive it and rev it to approx 6000rpm (I'd guess 5500-6000rpm), then it idles at 1300-1500rpm. You can drive it civilly and it will still idle at 900rpm.
I let it run for 10-15 minutes hoping it would drop down to normal on it's own. Doesn't.
You can however turn the ignition off, restart it immediately and it idles at 900rpm again.
Swapped out ECU's and IAC's with known good working ones. Nothing changed.
Throttle body has been cleaned.
TPS is set (switch clicks just as it should).
Coolant temp sensor is working (could be wrong year model?).
Diagnostic code shows a 311 - "Vehicle speed signal missing" (we are not using an electronic speedo)
I've checked and looked over everything I can think of at least 5 times and I'm out of ideas.
Any ideas?
RSI Stage 1 cam.
Any ideas?
