cathoderayfish
- Jan 8, 2025
- VA <--> NFLD
Hello, I have been having a small but notable power steering leak in my '86 240 for quite a while now, but it has been slowly getting worse and I figure it is about time to fix it.
I identified for sure that the leak is coming from where the steering shaft enters the rack: cleaned the area around the leak and found it leaking from the pinion seal; the shaft also has a bit of play in it and that seems cause the leak: if I invoke the play in the input shaft, I can visibly see some steering fluid leaking around the seal.
So my questions are:
-Is a slight amount of lateral play in the shaft expected at the pinion shaft input to the rack?
-Could this leak be fixed with simply a new seal, or is there some other component causing the play that also needs to be replaced?
-Could this fix be done with the rack installed in the car or would it need to be removed?
I found this that IPD sells which looks like it may work, anybody have experience with this kit and can speak to the ease of install and quality of it? (I would not be rebuilding the whole rack, just using what I need probabaly)
Here are some pictures I attempted to take of the leaky seal:
the part number on the seal is: 34002507.
