Mueller
- Oct 12, 2004
- Antioch, CA
where is a good place to buy in the US?
would it kill you to actually begin reading at the beginning of this thread???
Lol the links dont work and i looked on that site for what hes talking about and i couldn't seem to find the exact parts. I found the threaded sleeves and what not though.![]()
not sure what the coleman sleeves are made of (aluminium?), the compbrake kit has steel sleeves.
apart of weight(and material) Which differences the sleeves have?
only real advantage I see of the steel sleeve is that you could weld it directly to the strut housing...
perhaps the aluminum sleeve could get damaged more easily from flying rocks and debris, but cheap and easy to replace if that happened...
The compbrake stuff worth $23.63 (at today exchange):http://compbrake.co.uk/shop/product_info.php?cPath=9&products_id=299
depends on your location
not worth the extra money one would have to pay for shipping in my opinion![]()
I'm going to try these Torrington bearings on the lower perch when I get around to buying short struts and new coilover tubes/hardware. Assuming they work as designed, it will allow the spring to rotate so that it doesn't bind when compressiong or turning.
There's a lot of friction between the upper perch and the spherical bearing.
