- Jul 30, 2002
- Rockville, MD
But for Trackcar use only?
For track use only they are ok, but usually should be cleaned for every few hours of track use.
Using a sealed bearing is much more efficient.
and stock volvo strutmount...
The spacer shown in that picture..... I don't think that was in my kit I bought from the guy, or I forgot to install it. Does that go between the strut mount bearing and the tophat?
What's the adjustment on this set up versus there short strut set up?
IMO, the max lowering you can do on a factory length strut housing is about 2" lower. Beyond that you will be sacrificing compression travel and ride quality. Once the housings and dampers are shorter you can go beyond the 2" point and maintain good damper travel in both directions.
We designed some struts back in 2009 that had adjustable strut mountings. I think we produced one prototype set for our 850 racecar.Have you ever made a strut assembly that the spindle is adjustable up and down or just raised up?
http://www.elephantracing.com/suspension/coiloverkits/911coiloverkits.htm
BTW, that setup is not adjustable for spindle height... from what i see in the pic. The function of that part is the same as what you get with the QSRC i make.
It could easily be done, IMO its not beneficial enough to warrant the sacrafice in unsprung weight, stiffness penalty, and strength penalty of that design.
It's a way to make one part that works for a lot of applications but IMO its a huge compromise, Unsprung weight is highly critical and adding it without benefit is a mistake, imo...
I think the correct way to do it is to tailor each suspension setup to each car and the individuals needs.
Followed the Kyote Way and came up with these. Kaplhenke sleeves and spring hats, tubes shortened 2.75", Oldsmobile/Buick strut inserts (SUPER tight fit) and 8" 400/lb springs.
Gotta fab some bushings brov... 2.58mm of radial slop is no beuno.
Got to install them correctly bro, the 22mm part doesn't sit next to the 17mm part.
Ben,
So what is it I am doing wrong? Does the spring seat not slide onto the strut shaft and then the camber plate?
so the spring plate will slide all the way down the entire strut shaft to the body? I thought it rested on the edge.
