Mueller
- Oct 12, 2004
- Antioch, CA
yea, I really, really want to run "racing" suspension springs on my car that cost about $15 brand new !!!
We put used springs on the lemons car, and even those cost $40. If I knew I could get NEW springs cheaper, I'd have done it.yea, I really, really want to run "racing" suspension springs on my car that cost about $15 brand new !!!![]()
Mueller. you never did say how the fitment on those KONI 8610's went.
I liked them once I went with 400lb springs....
I'm planning to try my 8610s with a 350lb spring on my 940, what springs did you try them with before?
Just how low can you go with stock length struts (without bottoming the struts out)? Anybody have pictures?
pretty much. I got away with stock length revalved HDs for a long time with 475lb springs. ~3x the rate of a "sport" spring will help keep off the bump stops.it would depend on the spring rates....general idea is that anything lower than ipd springs (1.75" or so drop) and you run the risk of bottoming out a stock length insert if you hit a big enough dip
I have a set of 940 struts made into coilovers, 'What should I use for springs?' The kit came with 200lbs. springs. Going into a 780 Turbo. thanks and hope this isn't a thread jack?
just recieved those "springs" from summit and it only is one spring for the above mentioned price of 34.99
I ran 8x325 springs on the front with off the shelf HD's. Never had any bottoming out and it felt pretty well damped for street use. Never did any autocrossing though, just some railing through the canyons near my house.
