JW240
All idiot, no savant
- Aug 15, 2004
- The Netherlands, Europe
Want to calibrate the speedometer of your 240? Here is how!
The speedometer is controlled by a ITT UAF2115 chip. This chip is used in many cars of the same era, including the 7/900 series.
There is a calibration resistor in the cluster that will alter the speed shown by the meter. The trip/mileage counter calibration is not affected by this resistor.
Parts needed: A normal 1/4 Watt resistor in the 56+ Ohm range, I used 61 Ohm on my 240 to calibrate it. Thin wire. Screw terminal. Solder+desolder wick.
Here ya go:
After you have removed the cluster from the dashboard and removed the speedometer unit itself you'll be greeted by this sight. Shown here is the PCB with the chip and calibration resistor and many other components. The green arrow indicates the calibration resistor.
Desolder here.
The resistor that was in this place was the calibration resistor. I used some thin wire and drilled a hole in the back of the case to mount the resistor outside of the case for easy calibration. When you drill the hole make sure that no shavings are left inside of the cluster that will cause problems later on.
The resistor is connected to pin 4 and pin 13 (ground) of the chip.
Here the resistor mounted on a screw terminal thingie. Pro tip: if you need to fix speedometer gear, its helpful if the wire for the calibration resistor can pass through the hole, its helpful of the resistors are connected via such a clamp vs crimped/soldered.
The stock resistor is about 56 Ohm. If you increase the resistance value the speedo shows less km/h or mph. On my car i replaced the resistor for 2 in parallel that are ~61 Ohm combined iirc and the results are very good. 50 km/h on the speedo is 48-49 km/h GPS and 120 km/h is 119,5 km/h GPS.
Some data found on the back of the VDO unit. K=6091 Imp/km - 437.204/002/041
Thanks to the Brickboard speedometer calibration article (for 740) and TB member blabla (BTI Volvo modifications) for reminding me of this possibility.
Extra:
ITT UAF2115 Speedometer and mileage indicator chip datasheet
You can change more stuff about how the speedometer reads and the mileage counter works, for example changing the amount of pulses needed etc (page 2, grounding/floating/connecting pin 11 etc). Can be handy for people swapping in ABS rear axles or triggering the speedometer with front axle abs tone ring etc and when swapping between 12/48/96 tooth tone ring stuff. Though I have not tried this yet.
Extra 2:
More good stuff here: http://cleanflametrap.com/speedo.html
Extra 3: Running a Truetrack with homemade trigger wheel now and the later style aluminiu diff cover, works great. Not sure how it works in stock form since I had to adjust sensor clearance anyway (Using a rubber ring or thick gasket sheet is fine).
Hope this helps
Edit 2: finally fixed the broken links. Things have been crazy here.
Here ya go:
Desolder here.
Extra:
Extra 2:
Hope this helps
