smeha
Tranny Whisperer
- Mar 3, 2017
- California
Hello people,
The car is 1988 245DL Volvo(Chrysler ignition, LH2.2)
Last night the car started and after few minutes of driving it stalls after choking a bit for half a second couple times.
Starts right up, idle is fine, but when I would rev past 1-1.5k RPM it would stall and die.
Little by little I got it with couple stalls and driving 5mph home.
In the morning, warmed up while doing tests, reved it and then drove the crap out of it for 10 minutes and ITS FINE.
RPMs are all to specs, TPS(new) and MAF sensor(used) were tuned and replaced about a month ago.
Throttle body taken apart and fully resealed and adjusted to specs about month ago as well.
Fuses are fine, FPR doesn't leak fuel out of vacuum, both fuel pumps make noses and they were replaced about 5 years ago, fuel filter replaced 3 months ago.
I have in tank fuel pump laying around just in case when 3-4 months ago it would drop to 0 RPM few times and then caught back and drove normal on the freeway, I started with fuel filter and the problem seem to go away.
Can someone please help me with what is going on and what should I do?
Thank you
Thank you
