sim
Mere Drab Mob
- Jun 12, 2010
- Port Moody, BC
I did the G80 swap last fall in our 242 and it made the snow so
much better last winter. I measured the backlash and took a
pattern when I swapped the carriers to ensure the gears did not
have a short life. Everything worked out with no messing about
with shims, I simply swapped them over from the open carrier to
the G80. I also replaced the carrier bearings. I left the pinion
gear alone at the time.
I was quite impressed that I managed to do the swap without
breaking anything. I've been enjoying my new shop press and
especially my new dead-blow hammer since. They were cheaper than
the shop time would have been.
Since then, the diff has developed a nice leak from the pinion
seal. While I value the rustproofing effect, the smell from the
stains on the driveway is awful, and I worry it will run dry and
write off the gearset in the diff.
Is there anything I need to know before attempting to replace the
seal?
I've got a new seal ready to go.
I'll pop the cover and check the backlash again as well as the
meshing pattern. I'll count the turns on the pinion nut and
replace it to the same depth.
I've heard that the pinion nuts are single use? I can't even find
replacements on the iPd or FCP websites, though I suspect the
local Napa could hook me up.
I'm diving in tomorrow, as it happens the U-joints need doing
also, so it's drive train day.
Any tips?
Any gotchas?
Thanks for any advice.
seal?
Any tips?
Any gotchas?
