As hi-perf auto shows.
The OEM rubber bushings late torque rods/dog bones are nice & quiet when they?re new.
I can see why the factory designed them that way.
That said, the early ?hour glass? torque rods w/the harder of the OEM bushings squeezed into them last way better & are waaaay stronger than late or poly & way quieter than buzzy poly?
The early type rust at the weld/break in salted or rust coast cars, but we?d ?double skin? the early hour glass dog bones for ultimate rally/demolition derby nut job abuse & hysterical laughter uses on a budget?
I?m down to only 3 or 4 spare sets of rust free early, not sure I want to come off any of them or if quality OEM Boge stiffer rubber bushings are a NLA these days?
It?s a real PITA Press & glue the early in & out?miserable!
I?d just look for grandmas ?81-?82 garaged cool weather inland no salt 3 speed auto/tall rear axle gutless B21F/B21A/D24 (tho almost too much off-idle take-off torque in the case of the D24 LMAO
) ~80-100hp (when new, much less wheel Hp thru the AW/BW-55!) low miles smooth roads 244 donor car for good early dog bones for a consummate junkyard dog on a budget??
Last year of early varies, ~?80-?83 depending on model/trim level?
Iirc V6 & turbo got late (quieter) type earlier from what I?ve observed walking past thousands of cars per year when they were thick in the JYs.
If you had an earlier car that needed those bushings, often the dealer replaced them with late assemblies with the Volvo tag.
If your bushings were worn out, generally, often the dealer would install a late model torque rod complete assembly with the bushings already pressed in / quick labor time and they often had them in stock at dealers here rather then have the dealer grease monkey dig for the press tool & spend the ~1/2 hour+ start to finish press all 4 of them (if all went well?) just-so with the risk that the car had been running around with them loose & late model eyelets were egged out oval/oblong and wouldn?t hold the OEM bushing shells tight anymore, were rusty/crusty, or bound up/didn?t want to press out & back in smoothly?
As long as the upper arms stay tight but with *some* rubbery vibe absorption/articulation & compliance & you use quality OEM replacement rubber parts & drive on smooth cool weather roads gently without jackrabbit / light-light drag strip starts/hot rodding around, you should rarely have to change the big PITA lower bushings in my experience?
?tall skinny 14? vanagon tires with plenty of sidewall on ultra light strong Bertone Lego, 240 Classic/scorpius-X (no fun to clean) or GT 14? wheels. (Or lighter of the Coronas w/stainless acorn lugs but I don?t like them much (can only really use sticky weights/don?t take a beating as well S the others) of the OEM choices are probably best for suspension longevity?
14? quality tires with good selection/junkyard-able are getting rarer & early steelies take more abuse than alloys even if they can rust/are heavier & more unsprung weight?
Over loaded without overload springs to keep the back level or shocks allowing too many oscillations towing or up the wash board boat ramp is also pretty brutal?
They kinda had the design more ?right? on the 140s, but the OEM giant bushings allow for more compliance on the front of the lower arm on those & the 4 link doesn?t stick up from the axle tube to control for torque/thrust under power as well on the 140?but 140s were also lighter & had less power/torque than a 260 or something?
140s are definitely sketchy when the big bushing in the front of the lower trailing arm bushing is jell-o soft or worn compared to 240s with worn axle bushings?
To my knowledge, a 164 1031 bolts into a 140 up to 1974 before the ?75 164 was essentially a 200 series from the firewall back, so idk what they did for B30 torque/power??harder compound bushings? Wasn?t an issue in the warranty period if there even were warranties hardly in those days?
I don?t know much about 164s?they?re crazy obscure & I got no use for a sedan & use/abuse wagons as a defacto pickup truck?
