Jussi Alanko
- Jun 5, 2020
- Finland
So, i had bought a 81mm bore block, i had a 2.0t crank.
Everybody knows what i need next 2000-2004 b4204s cylinder head with solid lifters.
I will try to make myself a flowhbench, it iis like longer term project so i don't think that i can measure my own porting.
But i section my porting work at different sections and get it to proper flowbench, my friend builds engines for work...
I do not make ports themshelf much larger, maybe 10% max, but more important is flow, laminar/turbulent, speed changes drastically which means pressure drops in differents part of the port-seat-valve combination. So, i can put a 33mm intake valve to it quite cheaply, at Kl-racing stainless valves (33mm, stainless steel) cost about 150€, But seatwork is going to cost, i maybe can get rid off old seats (with modified old intake valves that can be welded to seat, then put in a owen the cylinder head, wait at least one hour, then just whack them out. But installing a new seats is different thing and of course you had to be able to cut proper seat angles to it!
Lest think for a moment that i can get seats and valvework to be done at 500€, which is a pure guess, i have made these things about 20 years ago to b23 motors etc.
How much the intake channel flows as a whole, i do not measure it with an intake manifold on( because overpressures n turbe engines and various other reasons that will affect negative to cfm number but in a real world could get an engine either reactive or sluggish... too long to explain in this kind of format.
