I thought I should probably post an update on the car. A good amount has gotten done.
I gave up on trying to soup up a B18D and just decided to get myself a B20. I ended up picking up a '73 B20F from Redwood Chair that originally came from Pat's 1800ES.
I decided to replace any gaskets that would be difficult to reach once the motor was in the car. Mostly that just meant replacing the oil pan gasket and making sure the transfer tube seals were OK. The engine apparently only had 15k miles on a rebuild and it definitely looked like it inside.
The engine as it was once I cleaned it off with a lot of simple green. The water pump was relatively gross so that had to go. As did the block off plate for the mechanical fuel pump. I ended up filling the injector holes with freeze plugs. I may also pick up some of the little plates SW EM sells and go full belt and suspenders.
Shined up the aluminum parts and whatever they plate the valve cover with.
New coat of red paint. Also tore down and lubed the distributor. As it was a D-jet car it has a pickup the distributor. It puts out less total advance than the B18D cast iron unit but given that the D cam has a longer duration I went with a higher base timing and lower mechanical advance. I left the vacuum retard disconnected.
The old motor came out. Puking coolant everywhere in my driveway. Although this car is probably the easiest engine removal I have ever done.
New engine ready to go in and cleaning up the transmission.
New motor in. For this I decided to put the engine in first and then install the transmission. Compared to the weird rotate and lift motion for an M47 in a 240, fitting an M40 in an Amazon is easy.
Everything cleaned up and installed. Since I didn't have a manifold for a car with a closed PCV system I just routed that to the little plug at the end of the balance tube.
I ran into some trouble with fuel pressure right off the bat. Turns out my mechanical pump was putting out far too much which caused the rear carburetor to run overly rich and squirt fuel out the float bowl vent. I made a small bracket and picked up a fuel pressure regulator.
Whoever at Volvo decided on blue air filters had obviously not thought about how much it makes the engine look like a tonka toy.
The car now feels more driveable in modern traffic. It is still not very fast but I can put my foot down at highway speeds and actually accelerate. Merging isn't anywhere near as dicey. The D cam pulls well from the start. It might also be that the old motor had issues I couldn't see at first glance.
Not pictured was the trial of changing the door hinges. It is a nice feeling when the doors close like they should and you don't have to lift them a centimeter.
Next up, finishing the interior side panels and dealing with the back seat.
