- May 11, 2007
- Niketown, OR
it will run pig rich without a way to subtract fuel when out of boost. what i did was just a bare bones +t for those who want about 150hp out of regina.
if you want to start changing injectors and stuff like that, talk to 740volvo as he knows what aftermarket tuning components are needed to add to regina or trick it into working with much bigger injectors.
the +t i did here was a 2 hour job, what he did probably took longer than 2 hours.
my purpose was to prove that regina could handle a +t without adding any extra fuel/ignition controllers. if you want to start running bigger injectors, more boost and stuff like that you will need these things.
Got it, for a second I thought it was as simple as making K-Jet run pig rich on boost only. I'm probably going to run SMT6 as some of my buddies here have a lot of experience with it.
The SMT6 will help a bit, I would say get an airflowconverter witch tricks the ecu and makes it think it's not reading pressure and you can control the % of the gasoline.
I run 440cc INJECTORS with Regina and the VAFC on 14psi w/out a problem I also have a walbro 310 in tank (11.8 AFR).
I get about 25-29 mpg on the HW and about 21-23 in the city (aka stop and go).
The VAFC sounds bitchin' though. I did some reading on it and the thing has a great interface. Sadly it might be a bit out of my price range.
About the airflow converter, you are talking about getting a converter on top of the piggyback? What would be the point?
I figured that if I can't make it work properly on Regina I can just install 2.4 with a 240 harness instead and call it good (changing the pressure plate would be a pain, but whatever.)
That's still good though Matt you did a great job, I just went out of my way to be different and make it work with bigger injectors, I guess that's why I went from slammed Hondas to slammed Volvos![]()
