blandoon
the last & the spurious
- Jul 6, 2012
- Eugene, OR
I chased down an ignition problem on my '86 740, and I found the coil wire all corroded at the cap due to the boot not sealing properly. I switched to the block-mount distributor about 2 years ago, and put on new plug wires then, but I think the coil wire was never the right one.
240 type cap+rotor are easy enough to find, but the coil wire needs to be for block-mount distributor with Bosch coil on the passenger side... what wire set do I get that has one like that? Maybe an '84 760 Turbo with B23FT... or some of the early 240s had the coil over there (which years?)
