- May 27, 2008
- Rockland County, NY
located another tailgate. Had to remove glass & chop it up ahead of time - won't fit in my C30 otherwise. I left enough meat to work the cap as per StiggyPop
After washing the bay, the engine wouldn't start. Turned out, washing it killed the coil. On the backside, the epoxy is all cracked, so obviously water got it. The used one I got has minor cracking, so I'll cut it back & re-epoxy the backside before moisture gets in.
Since I had the parts, I added cruise whilst I was under the dash adding vacuum line for the turbo gauge that will be going along with the +T in eventually. Had to dig around for the harnesses - it's been at least 15 years since I worked on a 700 series.
brain & pedal switch.
pump
stalk
vacuum
got a late wider rad & IC - not sure if this one fits.
turbo/manifold
some of the hoses
Used IPD bars set & crossmember brace
pump
stalk
vacuum
turbo/manifold
some of the hoses
