- Feb 2, 2007
- Falls Church, VA
many volvo owners find that the a/c compressor on their car develops a condition where the compressor clutch does not engage after prolonged use or just not at all. the issue is attributed to the gap in the compressor clutch being too wide for the magnet to engage it. a lot of people replace the clutch or compressor itself which does indeed fix the problem but takes time and costs money.
being that this is turbobricks and we are all about the cheap reliable fix, let me show you how i've been fixing this issue on my own vehicles, coworker's cars and friend's cars. there's articles floating around the internet that show how to do this various ways. the first time i attempted this cheap repair, i used bread clips as instructed by the internet. it worked for about a day and then the clips flew out of the compressor. i tried to do it again and the same thing happened. i devised a way to do it reliably using mechanics wire while the compressor is still on the car. i've seen this done with bread clips but they fly out. i've seen it done with strips of metal but it requires the clutch to be removed. i've seen it done with zip ties but after a while they slip out of place. i came up with something that works better than the other ways i've seen it done.
for demonstration purposes i took pictures of it being done to a compressor off the car so it's easier to see. the compressor does not need to come out or even be unbolted to do it.
on FWD volvos it is a lot easier to do this with the front subframe lowered. don't let that scare you, it's real easy and the engine won't fall out. you just remove the two 18mm bolts holding the front of the subframe up. i don't even use a jack to lower it because it doesn't come down that far. it won't fall or scare you when it comes down so don't worry. once the fix is done you can bolt the subframe back up. you may need to jack it up a touch to get the bolts started, i just lift it by hand and get the bolts started. that's it, you don't even have to take the belt off.
let's get started.
here's an a/c compressor that has too big of a compressor clutch gap. it stops engaging after prolonged use on hot days. take note of the gap, it may not look like much but trust me, the gap is too big.
<a href="http://s294.photobucket.com/albums/mm104/promise383/repair%20articles/?action=view¤t=S6303756.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm104/promise383/repair%20articles/th_S6303756.jpg" border="0" alt="Photobucket" ></a><a href="http://s294.photobucket.com/albums/mm104/promise383/repair%20articles/?action=view¤t=S6303757.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm104/promise383/repair%20articles/th_S6303757.jpg" border="0" alt="Photobucket" ></a>
now here's a piece of mechanics wire long enough to do the job. if you don't know what mechanics wire is, google it.
<a href="http://s294.photobucket.com/albums/mm104/promise383/repair%20articles/?action=view¤t=S6303758.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm104/promise383/repair%20articles/th_S6303758.jpg" border="0" alt="Photobucket" ></a>
now you want to rotate the inner part of the compressor clutch so you have good access to one of the rubber dampers at the corner of the triangular spring mount. using a long flat head screwdriver, pry the compressor clutch in so you have enough space to push the mechanics wire behind the damper as pictured. you may want to use two long flat screw drivers, one to pry the clutch back and one to help push the wire into position.
<a href="http://s294.photobucket.com/albums/mm104/promise383/repair%20articles/?action=view¤t=S6303761.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm104/promise383/repair%20articles/th_S6303761.jpg" border="0" alt="Photobucket" ></a><a href="http://s294.photobucket.com/albums/mm104/promise383/repair%20articles/?action=view¤t=S6303762.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm104/promise383/repair%20articles/th_S6303762.jpg" border="0" alt="Photobucket" ></a>
once the first corner of the clutch is done, rotate the inner part of the clutch 120?, that's 1/3 of a turn for those who didn't make it through elementary school. next you want to pull the wire taught and push it behind the second rubber damper as pictured here.
<a href="http://s294.photobucket.com/albums/mm104/promise383/repair%20articles/?action=view¤t=S6303765.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm104/promise383/repair%20articles/th_S6303765.jpg" border="0" alt="Photobucket" ></a>
if you were one of the people who understood what 120? means, you can probably guess what we're going to do next. that's right, rotate the inner part of the clutch again and push the wire through the last rubber damper.
<a href="http://s294.photobucket.com/albums/mm104/promise383/repair%20articles/?action=view¤t=S6303766.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm104/promise383/repair%20articles/th_S6303766.jpg" border="0" alt="Photobucket" ></a>
pull the wire tight and twist it together by hand, then cut off excess wire BUT don't cut it all off, leave about 1cm of twisted length for the last step.
<a href="http://s294.photobucket.com/albums/mm104/promise383/repair%20articles/?action=view¤t=S6303767.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm104/promise383/repair%20articles/th_S6303767.jpg" border="0" alt="Photobucket" ></a><a href="http://s294.photobucket.com/albums/mm104/promise383/repair%20articles/?action=view¤t=S6303768.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm104/promise383/repair%20articles/th_S6303768.jpg" border="0" alt="Photobucket" ></a>
take some needle nose pliers and twist the wire so it's uniform and taught. don't go crazy on it or you'll break the wire.
<a href="http://s294.photobucket.com/albums/mm104/promise383/repair%20articles/?action=view¤t=S6303769.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm104/promise383/repair%20articles/th_S6303769.jpg" border="0" alt="Photobucket" ></a><a href="http://s294.photobucket.com/albums/mm104/promise383/repair%20articles/?action=view¤t=S6303770.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm104/promise383/repair%20articles/th_S6303770.jpg" border="0" alt="Photobucket" ></a>
lastly, bend the excess twisted wire so it's flush with the rest of the wire.. not really required but it makes it look less ghetto. your finished product should look something like this.
<a href="http://s294.photobucket.com/albums/mm104/promise383/repair%20articles/?action=view¤t=S6303774.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm104/promise383/repair%20articles/th_S6303774.jpg" border="0" alt="Photobucket" ></a><a href="http://s294.photobucket.com/albums/mm104/promise383/repair%20articles/?action=view¤t=S6303777.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm104/promise383/repair%20articles/th_S6303777.jpg" border="0" alt="Photobucket" ></a>
check out your new compressor clutch gap and compare to the gap pictured up above.
<a href="http://s294.photobucket.com/albums/mm104/promise383/repair%20articles/?action=view¤t=S6303772.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm104/promise383/repair%20articles/th_S6303772.jpg" border="0" alt="Photobucket" ></a>
and there you have it.
let's get started.
