Gussie
- Mar 30, 2004
Hello all,
About two weeks ago my previously-good-performing 300,000-mile stick-shift 244 backfired (for the first and only time) when cold. Since then has had a very nasty buck/surge beginning at very slight throttle in 1st and 2nd gears. The buck/surge is so nasty it'll chirp the tires and feels like it'll break something in the drivetrain - even though I'm barely moving the throttle from idle position.
The effect does not vary with the amount of fuel in the tank or air temperature. If I short shift into 2nd and accelerate very easily, then above about 3000 rpm it surges just slightly. In 3rd and 4th gears, power seems down slightly but the car cruises easily at 90mph. I drive the car 1000 miles a week (for two years now, most of it at 80 mph) and get about 24 mpg even with the current problem. It starts and idles perfectly. It passed smog about a year ago.
I've searched the site for tips and found a bunch. I put in new sparkplugs, wires, cap and rotor (old stuff was newish and everything looked fine); no effect. I changed the fuel filter; no effect. The in-tank pump was not working so I changed it; no effect. The main fuel pump fuse holder was cracked and corroded (and getting very hot) so I changed it; no effect. The throttle switch clicks just like the Bentley manual says it should. Main fuel pump sounds fine. When disconnected, each injector has the same effect on idle. I disconnected the AMM and then it idled very poorly.
Having ruled-out or addressed the most common problems, I'm stumped and would love your help.
Thanks
Marty
Thanks
Marty
