Meant to post this last week. As you said, its interesting to compare if nothing else. Mine has never been dyno tuned or looked at by someone with more experience who really knows what they're doing. That would be the best way to see if it is just a tuning issue.
I went back and forth over a hill where I could hold a load in third for a few seconds at a time. But holding it steady in that range is a little difficult, because that is where the turbo starts to respond quickly. That is part of what always made me think that some kind of "missing" MAPdot AE was being compensated for, but the MAP isn't actually changing fast enough to trigger one.
MSQ is the same as my last post.
MSL log:
https://drive.google.com/open?id=0B_ELhGS5O-W4UFVlTWlNU0IyNWc
1465-1570 is 100-120kpa and looks pretty good. The area leading in and out is rich. If I reduce the ve table for the rich areas, it will make the step at the 2800rpm bins even more drastic.
4910-5220 75kpa tapering down to 70kpa. A little rich leading in, but otherwise smooth. The 3k rpm ridge in the ve table below 80kpa is almost non-existent though.
6250-6295 is 85-100kpa. Just a short pull, but the large ve values kept the afr consistent.
7040-7120 is 100-150kpa. Another short pull with larger throttle opening. The ve1 value flattens off at 108 right as the afr starts swinging lean, and makes it look like that 120kpa/2800 rpm cell could take even more than the 109 value its already at with steeper drops on either side. The first record range I listed is like this too.
On the drive back, I payed more attention to how the car runs in that range. While accelerating the way I normally would in second and third gear, I notice that as the turbo spools up and the engine starts to really pull, it flattens off right in that rpm range, just for an instant, and then it immediately gets past it and pulls smoothly on up from there.
The lean to rich swings in the logs seem to be from 2850-3000rpm and the bins I have set are 2400,2800,3200,3600. I could change the rpm bins so one centers over that range with a huge ve spike, and the adjacent bins within 100-200 rpms back at normal values and see how it reacts. Its been really hot, so I haven't driven it since last week.
