93 940 headlight hi beam wont latch
vcolper
North Port, FL
I have an issue with the Hi Beams and instrument cluster/dash lights.
ignition on, light switch in center (parking lights) position. all work normal
ignition on, light switch in right (Headlights) position, instrument cluster/dash lights go out. lo beam good, Hi beam will not latch on. Just flashes when I pull on the combination (turn signal lever) switch.
Ive replaced the switch (I have five extras), replaced turn signal/combination switch (4 extras) and the light relay(K)(3 extras). Symptom continues as described.
Suggestions?
