mschultz373
- Mar 11, 2020
- dirty coast
i ended up cutting the sheet metal flaps under the front cross member to fit the intercooler beneath it; i missplaced the longer brackets shown in your pic Anthony.
in my foolish disorganized, i have to ask two additional n00b questions:
which linkage should I use to connect the 240 gearbox to the aw71 trans? these are the two linkages I have:
AND - these are the two heater core lines; i assume the line with the valve connects from water pump hard line to lower fitting on firewall (inlet to heater core)?
