Smorgesborg
- Apr 9, 2020
- Eastern MA
In short:
Alibaba 158mm H beams with 24mm wrist pin bushings, with crank steering (either 29.5mm wide or 29.75mm, TBD), and 4.8L/5.3L LS pistons.
How:
A bulk order of custom connecting rods from a factory I found through Alibaba. Pistons sourced from really anywhere, LS's are plentiful. The 33.655mm compression height of the LS combined with the 158mm rods is only a few thousandths of an inch lower than the compression height of the B230 pistons with 152mm rods. If it wasn't for the different rod requirements, it'd be a drop in replacement.
Why:
1. Weight savings
- 130g saved minimum vs conventional 152mm H beams and B230FT pistons
2. Greater Range of piston options for various purposes
- Overbore pistons for rebuilds are cheaper.
- flat tops, dished, cast, forged, etc are all available for the LS at low prices.
3. Makes a bored out B230 build closer within reach for less price
- the LS has a wide range of bores. Only needs to have a similar compression height and wrist pin.
4. More efficient
- Thinner rings
- Longer rods means better piston speed profile
5. Greater power potential vs stock
- Forged 4340 alloy steel rods are stronger than the factory 13mm ones
An explanation:
I came up with this idea for this mod, and I am looking to do it on my engine. While I realise crank-steered 158mm connecting rods are already in existence, I don't want to risk a relatively large amount of money by modifying the rods in order to accept the different wrist pin, nor do I think anyone else would.
China rods are cheap, CXracing 152mm's ones are popular, and I'm fairly confident, based on matching appearances, that a number of other well-regarded aftermarket sellers are also just reselling Chinese H-beams. I found a factory that makes custom connecting rods and has a pattern for a 158mm Volvo B230 rod, and allows for different small end bushing diameters. Downside, despite being relatively cheap, the minimum order quantity is 40 rods, and I don't have 10 engines to rebuild. I certainly don't want to absorb the entire cost if I just use 4.
And so, with that last point, I've come here. I'm probably not the first to have this idea, I've seen similar ideas floating around before, and I'm here to look for an additional amount of people to help me absorb the cost. The initial purchase would all be on me, of course, since you wouldn't want to pay for something before it's actually available, but I'm looking for people that would be willing to confirm that they'd be interested in buying such a package. The cost would be around 160 bucks for the package of 4, minimum. Might be more depending on shipping costs, the buy-in cost of this endeavor would just be enough to cover the cost I'm going to be putting in. Long term, if this works, I would be looking to sell these for more.
Since feeler threads aren't allowed in the for-sale section, and this is a performance modification, I've posted this here. Thanks for reading.
How:
Why:
1. Weight savings
4. More efficient
- Thinner rings
An explanation:
