Shifted
- Apr 28, 2007
- The Hill, Shinshu Japan
While finding my dead alternator I decided to improve my battery- to block connection.
Well-cleaned block terminal.
Add a little heat:
Old gunk flows out and is replaced with clean solder
I r serius...
And cleaning up a new spot for the ground:
The ground bolt removed earlier works just fine here too; wire is routed with stock hardware.
A good connection that's easy to check.
Add a little heat:
I r serius...
