Ongoing To Do List:
Maintenance/Required:
- Stage 0 (Oil,fuel, air, filters)
- Oil Leak
- Get Gauge Cluster/Install
- Reinstall all Interior Pieces
- Replace Leaky Booster
- Starter
- Proper Battery Tie Down
- Front Brakes
- Rear Brakes
- Rear Hard Brake Lines are Crushed (wtf)
- Front Left Caliper (super rusty but working/not leaking)
-Fuel Leak (Fuel filter)
- Trans Leak(Gasket?)
- New Tires
- New fuel sender unit(looks crusty AF) & lock ring + fuel hoses
- Timing belt (or just swap engine)
- Fix Azev Wheel Lug Seats (Damaged)
- Auto locks being weird
-Sticky Idle Valve: Replaced
Optional:
- Pop out kick dents
- Install new radio (stock volvo missing code)
- Fix or remove AC (TBD) Removed!
Performance/Fun:
- Install rebuilt B230FT with GT35R
- Install T5 Trans + Hydraulic Clutch
- MS(have harness and box already) or Turbo ECU/EZK
- Brake upgrade
- Scope Bosch 124 Dwell
- Scope AIC PWM
- Scope Injector Deadtime
Long story short, this car was abandoned at a Volvo repair shop near me. I've known the owner of the shop for a long time and occasionally get work done there on my V70(he also has like 5 storage containers full of 80-90s car parts, but that's another story). The shop after like 20 years didn't have their lease renewed, so they have to move, and with it all of their cars and parts. So to make things easy he was getting rid of some stuff, and I asked about this car(which was destined to have parts removed from it the rest of its life) and he said I could take it. Unfortunately didn't have the ownership, hence the part out destiny.
So I got a uhaul trailer with my suburban and picked it up!
The dash was partially ripped apart, someone cut off the catalytic converter and put two dents in the front and rear driver fenders with a kick
, key is missing, no cluster(the shop had it but I couldn't get ahold of them while moving), but otherwise the body is in good shape, and everything around here rusts to nothing, so this is basically perfect IMO. My plan was to cut it up for stuff for my 242, but after seeing how there were no holes at all I decided to get it back on the road.
Turns out it even has IPD sways on it.
Had to swap the ignition part which is really fun! And throw in a starter which I just stole off the 242 since its a shell right now. Band clamped some cat from a F150 and a new o2 sensor. Finally got it to fire up. Ebay'd a gauge cluster.
I spent awhile trying to talk to the shop to get the original owner to bring the ownership, or find the guy, to no avail I wrote an an affidavit of the situation and managed to get the ownership transferred over into my name. It was at the auto shop for nearly a year I think, and at my shop for a few months with no contact.
I threw some new brakes on the front and put the Azev Type As from the 242 I've had sitting for 10 years on it. Not too bad!
This will be the fun car for awhile, so I can figure out what to do with the 242. Might slap the built B230FT and T5 in it at some point if I get bored.
- Stage 0 (Oil,
- Oil Leak
- Starter
- Front Brakes
- Rear Brakes
Optional:
Performance/Fun:
- Brake upgrade
- Scope AIC PWM
