isaac
The Isaac
- Nov 13, 2002
- Hurricane River Street, FL
Because Michael suggested it, I went ahead and did 2 more tests to show off 3rd gear performance (as opposed to 4th gear in 2 of the last 3 tests) for the M and K cams. I was gonna do the B cam too, but only had enough time yesterday to test the M, swap it out, and put in the K and test it. Drilling out the broken pin in that cam has turned out to be a real bit breaker btw. I should put two notches in the end of the cam to signify this.
Anyway, about the new tests: A 30-50mph 3rd gear acceleration test (full throttle like all the others), and a 50-70mph 3rd gear acceleration test. All test conditions were the same, except it was a little cooler outside. K cam is 6 degrees advanced, M straight up.
The 30-50mph test started at 1,950rpm and pulled to 3,050rpm. Though this is just another torque test, it starts at a less 'unfeasible' rpm.
The 50-70mph test started at 3,050rpm and pulled to 4,350rpm. This test should help to better isolate the powerband between 3,000 and 4,500 compared to the previous tests I posted.
Results:
30-50mph 3rd gear acceleration-
M cam - 7.41 seconds
K cam - 7.726 seconds
M cam - 8.53 seconds
K cam - 8.243 seconds
You can see by this that the M is still the low end torque champ. However, side by side, starting in 3rd gear at 30mph and continuing to 70mph, the K, which was .31 seconds behind the M by 50mph, is hauling it in between 50 and 70mph. This means that somewhere between 3,000 and 4,350rpm, the K starts making more torque than the M. Anyone who's driven a K cammed car can tell you this, but there are the stats. Keep in mind that the K was running 6 degrees advanced. I didn't bother running it straight up, because like I've said before, it still pulls great to 6,000rpm and I've got a hard limiter at that point.
I started a new thread for this because I wanted everybody to see the results and figured maybe a few too many people got burned out about the verbal melee that the 'M cam vs. B cam vs. K cam' thread turned into.
Results:
